E36 31/28 won't rev past 5700rpm
Thread in 'Technical Questions' started by pikeydrift, Apr 28, 2014.
  1. pikeydrift
    pikeydrift Member
    Can anyone help me please I've got an s reg 318 with a 328 engine transplant. It's been working fine and bouncing off the limiter now suddenly it will not rev past 56-700 rpm!
    Thanks
  2. Shaarkey
    Shaarkey Member
    Friend had a similar problem with an 18is conversion he said there's too much airflow through the exhaust, engine requires back pressure to function correctly. I think his hit the limiter at the same point. Good luck
  3. Stavros
    Stavros Active Member
    Isle of bollocks
    That's total bollocks.
  4. 1N5_N15
    1N5_N15 Member
    New Zealand
    Quoted for truth
  5. 1N5_N15
    1N5_N15 Member
    New Zealand
    Try more like a blocked exhaust or intake. Or poor fuel flow
  6. pikeydrift
    pikeydrift Member
    Cheers all but I think I've pinpointed it to vanos solenoid seals
  7. Shaarkey
    Shaarkey Member
    haha worked for him.
  8. dan_gsxr
    dan_gsxr Member
    had this problem recently where mine would only go to 5.5k
    turned out to be the rear speed sensor! it sends a signal to the abs and that sends a signal to the ecu. if the ecu doesnt get the correct reading it lowers the rev limit. normally kicks in a fault for vehicle speed in the ecu
  9. turbokick
    turbokick Member
    It could be they have missed some sensor.
  10. pikeydrift
    pikeydrift Member
    Do you mean the sensor in the diff casing?
  11. dan_gsxr
    dan_gsxr Member
    no mate, the actual abs sensor in the hub.
    mine turned out to be the o/s/r playing up
  12. pecs
    pecs Member
    St Athan / Wrexham
    Had the same problem with the old 320. It will be one of the rear ABS sensors mate.
    You could pull your ABS relays, see if that sorts it.
  13. pikeydrift
    pikeydrift Member
    Right finally got to the bottom of it.
    After rebuilding the vanos with new seals it still didn't work, and turned out to be a lack of speed signal to the ecu I bridged pin 15 ecu to pin 2 blue plug back of dash after speaking to someone who had a similar problem and it now revs freely, just in time for wheels tomorrow!!!!
  14. olew3523
    olew3523 Member
    Manchester
    this happens to almost every engine swap lol, and when you pull the fuse to abs, ive ran the same bypass wire on every conversion ive done, gay ecu's
  15. kossa
    kossa Member
    I had same problem. replaced ecu and work for me .
  16. Brownie888
    Brownie888 New Member
    Peterborough
    Yeah had the same problem on all 3 compact 2.8 conversions iv done and just did the wire from back of clocks to ecu trick, also if you splice the wires for the rear offside abs sensor into the diff sensor wiring under the back seats works too
