E36 316i M50 2.5L Drift Car Mileage - 155000 miles. MOT – September 2016. Spec: M50B25 – Skimmed Head. 220psi compression across all 6 cylinders Hellrot Red – Recent Respray M-Tech front & rear bumpers. M-Tech side skirts. Custom made gear knob LMS Deep Dish Steering Wheel Sparco Evo Bucket Seat (Drivers Side) Standard E36 SE Seat (Passenger Side) Modifications: Custom Map Polybushed Front to Rear Solid Engine and Gearbox Mounts JOM Blueline Coilovers Small Case Welded Diff Hydro Z3 Quick Rack Cut Hubs Drilled and Grooved Discs Braided Brake Lines Front and Rear Strut Brace Front Camber Kit M52 Manifolds Decat Mishimoto Alloy Radiator – New Fan Clutch Cool Running Thermostat Aftermarket 6K HIDs. Black kindney grills. M3 Rear Lights Pressed Reg Plates. Digital Water Temp and Battery Voltage Gauges The car sits on a genuine staggered set of 17" Style 66 BMW alloys with 15mm hubcentric spacers up front (Wheels could do with a refurb) Recent Work: New rear backing plates, handbrake shoes and fitting kit Gear Oil Change Diff Oil Change Both front droplinks replaced Spares A couple sets of 15” skid wheels and Tyres Marragoni Slicks Front and Rear lights Throttle Bodies Inlet Manifold Bumpers Trim Brake Calipers Loads more that I can’t remember, I took a full van load for me collect the spares I’ve owned the car for about a month and decided it’s not for me. I was and still am using it as a daily driver so mileage will increase slightly. I bought the car with no MOT, all i needed was the handbrake fixed. I’ve used it for one Driftland track day and it’s a excellent and well setup drift car. The cars still registered as a 1.6 so insurance is cheap. The car starts first time everytime. It just had a full professional respray in it’s original colour (Hellrot Red) before i bought it. The bodywork is very clean and tidy considering the age and it being a drift car but is by no means a show car. £2200 ovno Car is located in Falkirk, Scotland. Contact number: 07969 980 220. Due to work, I can't answer on weekdays before 17:00. Any time before that, please just leave a voicemail or just text and I will get back to you ASAP. Cheers.
