E36 325i - Boosting help needed
Thread in 'Technical Questions' started by RawTurbo, Apr 26, 2018.
  1. RawTurbo
    RawTurbo New Member
    Hello,
    I found a E36 325i from 1992 with ( 158.000 km / 98.000 miles ).
    The car is perfect without rust and looks very good.
    I´m going to buy the car when I have clear answers and plans.
    But, now I need help!
    How much bar can I run on my E36 325i ( 1992 ) stock engine?
    I planned to install the Holset HX35 Turbo + K&N 57I-1001 Performance Air Intake System.
    Then I also want to know what I could install to ensure that my engine don´t breaks because off the turbo boost. I´m on budget, that means I can´t change all the internals.
    What I want:
    A bit more boost and a nice turbo flutter sound. I don´t need much HP.
    Just a little more boost and great turbo sound.
    Best regards,
    Raw
  2. KevlarRx7
    KevlarRx7 Member
    After cooler/intercooler
    Fuel cut defender
    Aftermarket exhaust boost controller
    I'd say thats the minimum you'd get away with. But someone who knows more about BMW's should be able to help more
  3. r3k1355
    r3k1355 Well-Known Member
    You'll need engine management and all the usual supporting mods unless you want to blow your engine to pieces.
    HX35 might be overkill for moderate power levels as well.
  4. bpdrifted
    bpdrifted New Member
    Hi.
    BMW straight 6 iron block engine is capable up to 400 hp (up to 1 bar boost) on stock internals, you need to decompression it. You can do 0.55 bar boost on stock compression and it should do around 300 hp. HX35 is too big for your budget plan. I would recommend GT30/GT35.
  5. RawTurbo
    RawTurbo New Member
    Okay, great. As already mentioned, I found a good e36.
    How can I check if that car that I found runs on an iron block?
    Do you mean non-vanos with "decompression"?
    Best regards,
    Raw
  6. bpdrifted
    As far as i know up to 1994 build year you will have M50 cast iron block engine with single Vanos or no Vanos unit (Variable valve timing system). Non Vanos is more interesting because of strong conrods. That's left one.
    105497646.
    You need decompression plate plus two head gaskets to drop CR ratio down from 10.5 or 11 to 8.5.
    • Informative Informative x 1
  7. DITUS
    DITUS New Member
    Okay, great! I can get a non-vanos one so that would be done.
    How much bar can I then run on that engine without chaning engine internals?
    Would 0,5 bar be okay for the engine block?
  8. bpdrifted
    On totally standard engine (with 10.5-11 CR ratio) 0.55bar is safe value.
