***E36 325i E46 Arms Hydro coilovers cheapness ! ***
Thread in 'Drift cars for sale' started by Wackojacko., Aug 30, 2013.
  1. Wackojacko.
    Wackojacko. Member
    Unfortunately the time has come to sell my E36 325i drifter.
    I essentially learnt to drift in this car, throughout my time with the car it has been reliable and very capable.
    Only Selling as moving into an S body and don't have room to keep it otherwise it would be staying for good !
    Spec :
    2.5 iron block (150k)
    Induction kit with cold air feed
    12" high power cooling fan on switch in car
    Ta Technix coilovers
    E46 bottom arms with new bushes
    Z3 steering rack
    4mm rack spacers
    Poly bushed trailing arms
    Corbra Monaco bucket seat
    TRS Harness
    Hydro handbrake
    Driftworks braided hydro lines
    HEL braided brake lines with 5.1 fluid
    Solid engine mounts
    Doubled up rear anti roll bar
    Battery relocated to behind drivers seat
    Deep dish steering wheel
    M3lights and front bumper
    iPod aux head unit
    It has had replaced in the last 200miles :
    Aux belt
    Radiator (old one looked a little worse for wear)
    Control arm bushes
    Rear trailing arm bushes
    New top mounts front and rear
    New windscreen
    New passenger window motor
    Brake fluid flush and braided lines.
    New cam cover gasket
    E34 solid engine mounts
    Car is MOT'd until November and taxed til the new year. The car has a few battle scars and the odd spot of rust but runs really well and skids really well. Will do Santa pod big track and most of Lydden hill.
    Jacking points are pretty rotten underneath but as with all e36's you have the external sill jacking points which are all spot on. Rear arches have been rolled badly so if picky you could slap some filler on them.
    Mileage on these engines is meaningless aslong as they're kept cool like this one they last for ever !
    Only other fault I can think of is the power steering lines leak a little and drip fluid now and again, easy fix and common e36 problem. Never rectified as never bothered me.
    I'd like £1450 but open to offers.
    It Will come a with a few skid wheels but also have a set of E34 BBS, 2 with brand new Nankang NS2's and other 2 have near new tyres on them, want £120 for them.
    I also have an M3 gearbox for the car should you want to do an M3 conversion or upgrade the box, that is also available for £150.
    Cheers.
    Please PM me with any queries :)
    Car is located in Denham, Bucks.
    Here's a video of the car at pod :
    Pictures and other details are found here in my build thread :
    http://www.driftworks.com/forum/drift-car-projects-builds/200077-e36-325i-first-drifter.html
    #1 Wackojacko., Aug 30, 2013
  2. Dirkd90
    Dirkd90 Member
    You have a PM
  3. silvertop
    silvertop der drifte schlag
    put some cash toward my R32!
  4. Wackojacko.
    Wackojacko. Member
    Bump with pics :)
  5. Wackojacko.
    Wackojacko. Member
    Bump up :) Open to offers peeps.
    Proper suspension set up on this, 0 camber on rear 3 degrees of toe out on the front the car is a joy to slide.
  6. Wackojacko.
    Wackojacko. Member
  7. Wackojacko.
    Wackojacko. Member
    To the top.
  8. Aaron328
    Aaron328 Member
    Would you consider selling the E34 BBS wheels separate?
  9. Wackojacko.
    Wackojacko. Member
    Yes mate. PM me.
  10. Aaron328
    Aaron328 Member
    You have PM.
  11. Wackojacko.
    Wackojacko. Member
  12. Wackojacko.
    Wackojacko. Member
    Weekend bump, open to offers and part ex against S13 /14.
  13. Wackojacko.
    Wackojacko. Member
    Bump, a few offers but no follow ups.
    Open to offers, I can only say no :)
  14. lyf
    lyf Member
    3• toe out on the front!!!?! Seems a bit much.
    How did you combat the track rods being too short when you put 46 arms on?
    Cheers.
  15. Wackojacko.
    Wackojacko. Member
    I believe they're E90 track rod ends. 2-3deg toe out seems to be the going set up on an E36 from what I've read up on.
    Regardless it drifts and handles so so well that even if it was not technically correct I wouldn't advise changing anything !
    #15 Wackojacko., Sep 9, 2013
  16. DtheBUK
    DtheBUK Active Member
    something must be wrong there mate! 3 degrees is loads!
    free bump, this car is good fun and skids pretty darn well!
  17. Big_jim
    Big_jim Member
    Which M3 gearbox do you have? 6 speed?
  18. Wackojacko.
    Wackojacko. Member
    It's the 3.0 5 Speed.
    Will find alignment paperwork later.
  19. Wackojacko.
    Wackojacko. Member
    Can't find alignment paper work. So cannot confirm I may have made a mistake from memory. However as Buk says it skids really well,
    Open to offers.
  20. lyf
    lyf Member
    Not spamming your thread bud just trying to advise on the toe issue.
    I run 15 mins toe out each side on the front of my 36 which equates to half a degree combined for the front.36 tracking probably only has around a degree and a half each side to work with.
    Never the less, yours is a good car for the money so goes
