For Sale e36 braking x2. Lots of parts avalible.
Thread in 'Parts for sale' started by Adam-MGTF, Jun 20, 2022.
  1. Adam-MGTF
    Adam-MGTF Member
    Teesside
    As title, have broken 2 e36 coupes and have many parts available.
    CONTACT EMAIL: umbrella.motorsport@gmail.com
    Parts located in Darlington DL11YF
    All body panels available. Prices from £10-£100. Please message or email with what you want.
    Engines: M52b28, good engine, has had sump modified for boost and has oil pressure line for a turbo but can remove if you'd like. Engine runs as it should, includes pink injectors and ancillaries. £550
    M52b28TU Tall block, no ancillaries or manifolds. Hasn't ran in 5 years but was a strong low mileage engine. £400
    Gearboxs: Not sure the going rate on these. Say £150? few available, all work fine
    Manual swap.... flywheel/clutch/clutch pedal and cylinders, mounts the lot. £250 with a gearbox.
    Diffs: Couple of small case welded diffs, again not sure on going rate. Say £100
    Shafts: Small case shafts. £50 each
    No interior parts
    I may have some suspension parts etc but i'll need to have a look. Message or email if there is anything you really need.
    Pictures on request if you really need them :)
