E36 compact engine info
Thread in 'Technical Questions' started by moleson01, May 24, 2015.
  1. moleson01
    moleson01 Member
    Glasgow, Scotland
    Hi guys,
    Recently picked up a little compact with a slow ass m43b16.
    Couple of questions - is it worth turboing? read a few posts on beemer forums, some say can be decent some that its a waste of time and just drop a 6 pot in it...
    Leads to my second question; can you mount an M50b20 straight to the m43 gearbox or will a gearbox be needed also?
    Also if anyone has any knowledge advice on good setups for these cars, it would be much appreciated.
    Thanks
  2. dannyboy94
    dannyboy94 Member
    I fitted a m50b25 to my e36 uses the 1.8 gearbox and 1.8 propshaft so you should also be able to use your original gearbox
  3. icebluesmx5
    icebluesmx5 Member
    medway
    I fitted a m52 tu to my e36 and I'm using the original 1.9 gearbox, prop and diff that was fitted
  4. moleson01
    moleson01 Member
    Glasgow, Scotland
    Cool, how difficult was adapting the two ecu/wiring etc?
  5. dannyboy94
    dannyboy94 Member
    It's plug and play with a ews delete ecu
  6. icebluesmx5
    icebluesmx5 Member
    medway
    I had to make a new loom to connect the e46 engine to the e36 car loom. Few problems but overcome them in the end and I'm still running the ews system with some mods done
