E36 Garage built Drift car
Thread in 'Project Cars and Builds Threads' started by C&H_MOTORSPORT, Jul 26, 2017.
  1. C&H_MOTORSPORT
    C&H_MOTORSPORT New Member
    Bit of an introduction,
    We are 2 mates from New Zealand,
    We are in the process of building an e36 drift car. 90% of the fabrication will be done by ourselves. On a budget.
    Car:
    -e36 325i sedan (Boston green)
    Progress Photos and information to come.
    #1 C&H_MOTORSPORT, Jul 26, 2017
  2. C&H_MOTORSPORT
    Bit of a run down on the car prior to it being put up on jack stands.
    As mentioned above the car is an 325i sedan, Motorsport and manual.
    Sitting on custom BC gold coilovers
    Wheels were, Riverside Trafficstars 18x8.5 / 9.5 staggered on 215/35
    4 point Half cage was built by Chubb, here in New Zealand.
    After blowing the diff at a drift day.
    The car was parked up and the suspension and wheels sold.
    received_10214317892849641.
    received_10214317893089647.
    received_10214317893129648.
    received_10214317892889642.
    received_10214317893169649.
  3. C&H_MOTORSPORT
    After stripping the front end and pulling the motor and trans it was time to give the engine bay a bit of a tidy up.
    We decided we were going to tube frame the front end. For ease of access, to simplify the front end and allow for clearance for the mini angle kit in the works.
    Few hours with a socket set and grinder and we cut the front tubs out, removed the brake booster, fuse box and most of the hardline (resr brake line is the only line we arnt re doing)
    Spent a Good while shaving every bracket we could from the engine bay for a tidy up and ready for the fabrication work.
    received_1521865167877225.
    received_1521866151210460.
  4. C&H_MOTORSPORT
    Boot was next on the chopping block prepping for a tubed bash bar and a fuel cell. A good chunk of weight removed so far. Still have the other side to finish up but the pics show the progress as it sits.
    received_1521879731209102.
    received_1521879697875772.
  5. C&H_MOTORSPORT
    And the fabrication begins. Made some templates from some scrap cardboard which ill transfer to 2mm sheet steel. So far i have made plates to cap the chassis rails and The tube mounting points, i chose to Box in the strut tower in to strengthen it up a bit.
    received_1521877381209337.
    received_1521877397876002.
    received_1521877401209335.
    received_1521877404542668.
    received_1521877394542669.
  6. C&H_MOTORSPORT
    Started welding up a remote mounted hydro setup today. Means we can run the master behind the drivers seat and only need to run a handbrake lever upfront. Again. Made a mock up to see if it would work. More pics to come
    20170724_180110.
    20170725_153626.
    received_1522516954478713.
  7. C&H_MOTORSPORT
    Did a render of what the car could look like once we have finished with the build.
    received_1522512301145845.
  8. Rs Adz
    Rs Adz New Member
    wow nice work looming forward to the tube front end
  9. C&H_MOTORSPORT
    Cheers mate. Hoping to get cracking on the tube front this weekend.
  10. KAS627
    KAS627 Member
    what software did you use for the rendering?
  11. C&H_MOTORSPORT
    Render was done through a small business I have a part in. Each render is custom made from scratch however the client specifies.
  12. Talal sweiss
    Talal sweiss New Member
    Any updates ??
  13. C&H_MOTORSPORT
    i will upload a few photos and updates shortly
  14. C&H_MOTORSPORT
    No major progress recently, between chris off racing overseas and work we have been pritty flat out.
    slowly collecting parts for the front suspension setup so far we have settled on:
    -s13/14 coilovers front and rear - TICK
    -e36 front camber plates/top hats
    -s13/14 front knuckles - TICK
    -s13/14 5 stud (5x114.3) front hubs - TICK
    -6 pot Willwood calipers and big brake setup up front- TICK
    -lengthened stock e36 Lower control arms - TICK
    -custom lock adaptor (in place of cutting and shortening the knuckles for lock)
    have found a adaptor online that i will post a picture of to get an idea of what they will look like
    23555320_1621691391227935_1322007424_o.
  15. C&H_MOTORSPORT
    got some more of the plate cut and tacked in place for the front supports,
    couldnt help but throw some paint down to see how it would look
    23546965_1621686587895082_1045603657_o.
    23555365_1621687691228305_1675287062_o.
    23555302_1621687617894979_1573753816_o.
    23547196_1621687621228312_519400013_o.
  16. RWDvolvo
    RWDvolvo New Member
    Nice work !
  17. 85dirty30
    85dirty30 Member
    As far as the angle blocks, which if I am not mistaken they are the CNC adapter blocks that move the tie rod in about 1.5" they have 0 ackerman, I am running the Drift Knuckles unicorn kit on my e30, but have fitted it to an e36, and the amount of angle is substantial, it may be worth the extra cash to drop on modded knuckles, and rack spacers, could probably piece together a kit cheaper than they sell them though
  18. G535
    G535 Member
    Wow very cool! Looks rear so far!
