E36 Rear coilover
Thread in 'Technical Questions' started by hammer88, Nov 10, 2015.
  1. hammer88
    hammer88 New Member
    Hello,
    I've built a dual use car (drift and hill-climb) and I'm looking to upgrade the rears to a coilover set-up with rebound adjustability. Rear coilovers for e36s go for silly money, does anyone know if I could fit coilovers from an other car, perhaps a S13/14/15?
    Thanks a lot!
  2. zeppelin101
    zeppelin101 Member
    You could always get an insert and make a housing body up for it; that way you could buy off-the-shelf Koni dampers (8610 or 8611 - search and a few different PNs come up with stroke length etc) and have them valved to your spec.
  3. hammer88
    hammer88 New Member
    Thought of that but Koni inserts are quite expensive at about 170 euros a piece, plus the materials and machining needed to create the housings.
    This is only a stop gap measure as I'd like to upgrade to something professional later on...
  4. zeppelin101
    zeppelin101 Member
    tbh, if you know what you're after and know a company who can revalve the Koni's then it will probably work out better than the vast majority of stuff on sale this side of £1500.
  5. hammer88
    hammer88 New Member
    I've had an other idea, I'll just buy a pair of second-hand KW's of ebay and modify them to fit them in the rear, if anyone is interested I'll post the results...
  6. stephenj
    stephenj New Member
    Feal Suspension Coilovers
    Doesn't look like you are from States but you should look into Feal Suspension Coilovers! They offer a true rear coilover for the e36 right at ~$1300. Believe they are running 10% off for the next few days as well too.
  7. Andy318ti
    Andy318ti Active Member
  8. Starkey
    Starkey Administrator
    Staff Member
    Check you PM's I have sent you a message.
  9. ERTmotorsport
    ERTmotorsport Member
    You can run Yellowspeed coilovers which run a a coilover setup front & rear!
