E36 touring 2.5 M50 swapped
Thread in 'Drift cars for sale' started by Jammygit, Aug 23, 2020.
  1. Jammygit
    Jammygit Member
    M50B25TU engine - cast iron block 189hp
    100k miles on the engine (now uses these clocks)
    Originally a 318 - 130k miles on the shell very clean no rust issues
    Mapped ecu - EWS delete + raised limiter
    M20 flywheel (lighter)
    New clutch
    Maxspeedingrods coilovers
    E46 front lower arms
    Polybushed lollipops
    B2D short shifter
    318 3.38 ratio diff
    E30 325 diff cups and TDS solid driveshafts
    Poly bushed engine and gearbox mounts
    Stainless exhaust manifolds
    325/328 twin exhaust
    Front plate delete
    Leather door cards
    M-sport steering wheel
    Poly bushed trailing arms
    Adjustable rear camber arms
    New throttle cable
    New water pump
    New thermostat
    Alloy thermostat housing
    Ram Air filter
    Oil/filter service when converted
    328 brakes front and rear
    Drilled and grooved front discs
    Style 33 turbine wheels
    Front 8mm wheel spacers
    Rare optional cup holder
    Push button start
    Pioneer radio
    Working original BMW torch
    Aftermarket tail lights (stock supplied too)
    Clear front indicators and side repeaters
    Rear wiper delete
    Engine bay cleaned up and painted bronze during conversion along with silver engine ancillaries
    Bad points -
    Paintwork isn’t great - roof is scratched up and passenger front door has a faded section
    Drivers outer door handle trim missing
    No front anti-roll bar fitted
    Cat heat shields rattle/exhaust noisy
    Power steering pump needs replacing/refurb
    Fresh 12 months MOT (15th August)
    HPI clear
    This car in my opinion is a great base and has most of the parts and work done that you’d want on an e36. However it isn’t perfect and will require someone to do some work to make it 100% and put their own mark on it as they go.
    Any questions just ask, can take photos if there’s anything specific you want to see.
    Car is available for viewings most days with prior arrangement, happy to jack car up for potential buyers to inspect etc
    Located in Slough
    £2300
    2033A5DC-FE3F-40D7-A5D8-83C0FDE40722. 2B6035A1-54EF-4C94-B931-3202384D227C. 5766143C-2C6E-42AF-8E59-4D63CF1A354C. 3F878ABB-5147-41AB-BFDF-97B57EFA9F1E. 3A86A5D1-DB0B-4B70-BFF2-CBFF8D86E332. D628DB05-114A-46E8-94AC-FDB9D2559966. C8B3B977-EA0F-4027-AEB3-6AC6851081D4. B8AC6041-BDB9-4789-9402-D336F9E51E88. EC601416-FBA1-448F-A48A-74E8BAA6CEB4.
  2. miffy
    miffy Member
    seems a bargain with todays prices , good luck pal
  3. Khananator
    Khananator Member
    Messaged you mate
  4. Jammygit
    Jammygit Member
    Power steering pump has now been replaced with a remanufactured one (18m warranty)
    Open to offers too
  5. Jammygit
    Jammygit Member
    Price drop - £2k
    Very cheap for the spec I think but would like it gone now
  6. jakey1992
    jakey1992 New Member
    Is this still available
