E36 Touring.
Thread in 'Project Cars and Builds Threads' started by J4CK, Mar 6, 2015.
  1. J4CK
    J4CK Member
    Ghetto
    BMW E36 318 2.8 TOURING
    Suspension
    Mister R coilovers
    E46 Arms with M3 bushes
    E92 inner tie rods
    M3 Anti Roll Bar
    M3 Drop Links
    Poly-bushed RTA
    Poly-Bushed Sub frame
    Solid Diff Mounts
    Drift works Adjustable Camber arms
    Modified Hubs
    5mm Rack Spacers
    Drilled and Grooved Discs all round
    EBC green stuff Pads front and rear.
    Engine/Trans
    Early M52B28
    Solid Engine Mounts
    M50 Manifold
    68mm Throttle Body
    Silicone maf elbow
    APEXI air filter
    Remapped ECU 7200rpm limiter
    Short Shift
    Poly Gearbox Mounts
    CCV Deleted and vented to catch tank
    Idle Control Valve Deleted
    Carbon Canister Deleted
    16” Electric Fan on switch
    New 328 Aircon Rad (Larger then standard 328)
    Metal Water Pump
    Metal Thermostat Housing
    Low Temp Stat
    Decatted Mid section Standard Rear. New hangers and gaskets though out.
    328 GETRAG gearbox
    New Dounut
    New Centre Prop Bearing
    318 Drive Shafts.
    318 Welded Diff
    New Sachs Cultch
    New Cultch Salve Cyclinder.
    Exterior
    Remotec 16X9.5 ET6 MAZ1 215/40/16
    HID Low Beam
    Amber High Beams
    LED side Lights
    LED number Plates Lights
    MTEC Rear Lights
    Inteiror
    Stripped Out rear.
    Front Bucket Seats fibreglass back.
    Ricco 3” Harrness
    Driftworks Driver Seat Mounts
    Nardi Steering Wheel
    Driftworks Hydro
    Willwood 0.625 Cylinder
    Drift works braided lines.
  2. Gogzy
    Gogzy Active Member
    Dunfermline
    wheres the pics?
  3. J4CK
    J4CK Member
    Ghetto
    Well this failed
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    #3 J4CK, Mar 6, 2015
  4. J4CK
    J4CK Member
    Ghetto
    Bought car done skid. Pretty much what happened
  5. J4CK
    J4CK Member
    Ghetto
    Wheels rubbed cut out the inner arch,
    Just need to wash the car change few tyres and on to lydden on the 21st
  6. J4CK
    J4CK Member
    Ghetto
    Done lydden again
    Done the stud conversion
    Picked a few tyres up
    Done skids
  7. Gogzy
    Gogzy Active Member
    Dunfermline
    christ you bought thsat shed from kiwi, hope you sorted out the upsidedownpineapple heads shit :)
  8. J4CK
    J4CK Member
    Ghetto
    Yeah I fixed all of the kiwi shit and done skids [emoji23]
  9. DanMateX
    DanMateX Member
