E46 323 Touring Limp Mode
Thread in 'Technical Questions' started by JaamesE36, Oct 1, 2019.
  1. JaamesE36
    JaamesE36 New Member
    Kent
    Mate of mine has bought an E46 Touring. We welded the diff fitted Coilovers etc but when skidding the car jumps into limp mode and limits revs at 5150rpm, no Engine light or anything. Anyone else had this problem? Even with traction fully disabled (long press)
  2. BreadBin
    BreadBin Rough Tonguer
    Wiltshire
    Tried disconnecting one of the rear wheel speed sensors?
  3. JaamesE36
    Kent
    Yeah we done that. Put it into limp mode and killed the speedo. Plugged it back in and speedo turned into a rev gauge lol
  4. BreadBin
    Wiltshire
    Lol! I did find some stuff about fuse 61 but that seems to be M3s - might be worth a try?
  5. RozeTheHornet
    RozeTheHornet Active Member
    Banstead
    Had this on my 318, 330 and M3 :D.
    Remove front left wheel, unplug the blue wheel speed sensor, cable tie it to the strut so it doesnt hit stuff.
    Should have disabled TC and ABS but speedo will still work and will rev to red line :thumbs:.
  6. RozeTheHornet
    Banstead
    No matter what fuses you pull, from my experience you will always have either no speedo, a hard rev cut, or full limp mode.
    Wheel speed sensor is the only thing I have found that works consistently.
  7. JaamesE36
    Kent
    Will give It a go cheers boys!
    Got another touring with similar problem. He hasn’t got a Rev limit but it’s really boggy when skidding. Straight line will spin for days but as soon as your sideways it just bogs down and dies has no power, is this sensor related or something else? E46 seem a pain in the arse!
  8. RozeTheHornet
    Banstead
    That sounds fuel related to me tbh, another issue I have had with my 540 is fuel cutting on corners. Simple fix in my experience is keep it filled up as much as possible...
