I recently bought this e46 325i from Niko @Aero Elite. However parents have demanded that the car has to go, so unfortunately I have to sell it under short ownership. Please note that car now has a removable front plate (magnets supplied by aero elite), as well as the front tint and stickers removed from the front windows and windscreen to avoid hassle from police. Overall, car drives sweet, no running issues, hasn’t ever overheated, recently drove 3 hours motorway with no problems what so ever - can be test driven any time. WHEELS INCLUDED IN SALE: 7TWENTY STYLE55 ON FRONT, JR32 ON REAR AS SHOWN IN FIRST IMAGE BELOW Please see spec below, it's only got high quality parts fitted. {} {} {} {} {} {} {} Suspension & performance BC Racing Custom Extra Low Coilovers with Camber/Castor adjustable topmount upgrade (10/8KG) Wizards of Lock 0 Ackerman Hubs Wizards of Lock Rack Spacers Wizards of Lock 45mm CNC Extended LCA E90 inner tie rods, e46 outer Strongflex subframe bushes Strongflex diff bushes Strongflex trailing arm bushes Subframe powder coated Front & rear topmounts reinforcement plates Wizards of Lock rear camber arms Born2Drift toe plates Can adjust toe and camber to 0 if required this way 320d solid shaft conversion Welded diff 5x114.3 hubs, all were new which I had custom drilled and additionally converted to studs. 5x120 PCD is also still useable. Rear jacking/crash bar. Has had fresh alignment. (due to new front alloys may need another if picky) Remapped ECU, raised limiter, higher idle speed for more water pump flow, sooner fan kick in, instant throttle response, thermostat opening earlier. Exterior Wrapped in TeckWrap olive with 3M Black sparkle roof HM Sports front bumper HM Sports side skirts HM Sports roof spoiler HM Sports rear overfender (arches were cut as high as possible to allow max low, max squat and max fitment) all sealed up so no smoke in cabin Musk front over fender (one damaged, will need replacing, HM do these now) Amber indicators - USDM activated Gloss black grilles New Badges Chrome tinted rear windows CSL Boot spoiler All red rear lights Rear bumper is included (M Sport bumper) and is wrapped car colour, just liked it more without. Interior OBP Hydraulic handbrake with high end master (new EBC rear discs and yellow stuff pads) braided brake lines. It's all black interior which is mega nice, with the carbon trims. Hydro locks up perfectly with short throw unlike most BMW hydro installs WOZ Hydro plate (0 flex) Fire extinguisher Replaced both front window regulators so they now work, however front drivers side is now temperamental again. The bad Few dash lights on (washer fluid, abs, traction control) - ABS and Traction control fuses have been removed. - Washer fluid bottle has been removed but can be replaced by new owner if desired. Interior is okay, but stripped past front seats Deleted back box, but as decided to run no rear bumper never welded the shotguns on, can come with the car though. Passenger overfender is glued together, it’s fine but doesn’t look amazing, will defo need a replacement if you’re picky. Comes with spare roll of wrap, will be enough to redo front wings and bumper if ever required. £6500 ono - NO SWAPS PLEASE You can message me on here or my insta: @leonroberts_ Feel free to send through any questions etc. - Located in Peterborough area.
