2003 BMW E46 330ci Turbo! Shell is nearly mint baring the odd stone chip 0 rust! The shell is registered as a 320ci still ill leave this up to the new owner if they would like to change it. I've covered roughly 10,000 miles with this setup always ran on V power and service on titan oil. MOT til Feb Running 380whp will see 500ish with some bigger injectors and a gt35 turbo. Strom 18inch 8.5j and 10j et20 wheels new a couple months ago HSD coilovers bought direct from driftworks Front and fully rear poly bushed Quaife LSD with 2.93 final drive - royal purple 75w90 diff oil used. (spare welded diff can be included in sale) 5 speed zf gearbox LED Interior bulb upgrade AEM a/f gauge Custom blacked out headlights with angel rings and hid kit Android stereo Reliable setup that's not laggy. Has modified hubs fitted with good lock. Braided brake hoses all round M-TEC Drilled & Grooved discs running the 330 break set up KSB Front splitter (chipped) Engine spec: M50 intake manifold Gapped piston rings (k64) Cometic head gasket 0.098” Running 15psi of boost 9:1 compression ratio New ARP rod bolts New head bolts New main bearings New connector rod bearings New oil pump - with chain tensioner kit New Vanos seals Head and block machine skimmed Black machine honed Decompression plate T3 eBay turbo Custom 2.5” - 3” decat exhaust Hopwood Motorsport exhaust manifold Baffle plate in sump New OEM water pump 4 point BMW spark plugs 440cc injectors Walbro 255LPH fuel pump 50mm external wastegate 600x300x76mm intercooler Twin disc clutch set from Hopwood motorsport MAP conversion by Hopwood motorsport Adjustable boost controller Mapped by Hopwood Motorsport Bad bits: Splitter is chipped Rear wheels could do with a refurb Slight rip in driver seat bolster Newcastle Upon Tyne £9,500 ... might partake in a swap if slightly more practical. Serious enquiries only please. {} {} {} {} {} {} {}
