Ecu master piggyback det3
Thread in 'Technical Questions' started by Mattvaughan180, Oct 6, 2019.
  1. Mattvaughan180
    Midlands
    Do anyone run one of these on a chaser or on any of there cars for that matter?? Just wondering if it’s any good or not? Seems cheap money compared to there stand alones
  2. chopaholic
    chopaholic Well-Known Member
    Ireland/Lincoln
    Although probably okay to do very very basic stuff with, I would recommend for you to save the extra and get yourself an ECU Master Black, worth every bit of the money they are. Even for safety of your engine alone.
  3. Mattvaughan180
    Midlands
    I know what you mean, just wondered if these are any good really as I’m only going down the route of changing injectors and a bigger turbo etc,done the same on my s14a and was using a Horsham daughter board with no issues so was thinking the piggy back will do roughly the same job
  4. LUX1
    LUX1 Member
    tried to wire a det3 up to a turbo miata, wasnt the best as its relatively hard to setup (in my opinion) as opposed to a plug and play (apexi fc) etc.
  5. Mattvaughan180
    Midlands
    I’m guessing the ecu master piggy back is very similar to the power fc?? Not to fused about wiring it in as it will go to whifbitz for that
