Thinking of selling my roadster (which I will probably massively regret) to get something a bit more modern for trackdays. Basic run down on the car, 110k miles No rust, never been welded MOT end of July 2018 Have some history with the car not a massive amount. Crystal white paintwork (presentable but not amazing, original paint) Mk2 1.8 BP4W engine conversion Flyin miata swap kit Summit rpm controller for vics Cobalt cat-back with custom tip Silenced de-cat (83db at brands hatch) Mk2 1.8 4-2-1 manifold Drilled airbox Bigger ht leads New plugs/oil/filters January this year Cambelt+Waterpump changed 2k Kms ago Engine using 1.6 clutch and flywheel as much lighter than 1.8 New gearbox oil New gearbox shift boots Aluminium Radiator Standard engine mounts with voids filled to stiffen Meister-r crd coilovers new 12 months ago 1.8 mk2 brake conversion New discs New mintex m1144 pads January this year (seen 2 track days) 2x new front calipers Superpro steering rack bushes Steering rack riser plates Pas rack converted to manual (proper way) Superpro rear arb bushes Braided longer front brake lines New brake master cylinder Supermiata dual duty alignment Compomotive MLs in 15x8 Yokohama AD08R in 195/50/15 approx 600 miles old Extended front wheel studs 5mm spacers on front 4.1 ratio torsen type II - Polybushed mounts Jass front tow eye Crystal front side lights Aftermarket mirrors Gv polyurethane front splitter Kg works style rear spoiler Genuine Mazda hardtop with heated window (not wired in) Aerial removed Rear bumper Centre cut Relocated rear fog light into rear lights GCR1 rollbar RSA 4 point 3" drivers harness Retrimmed door cards with armrests removed Speakers and radio removed (wiring still there so can be put back in) Poly front 1/4 windows with drivers vent Motordrive bucket seat (bolted to floor with side mounts, no sliders. Ideal for 6ft+ drivers) standard mounts included to be welded back in if required. Stereo blanking plate Vinyl soft top in good condition with removeable rear window Satin black sunstrip Sun visors deleted Car is ready to go, hardtop paintwork is pretty poor but looks fine from 10ft away, some paint peeled from windscreen surround where I canoeed up trying to wrap it black. I have spares to go with car (open diff, gearbox, brakes, mudguards, stereo etc) Slight exhaust rattle when car is warm, although it is pretty quiet. Car made 115.6WHP at Skuzzles. £2795 {} IMG_20171231_155837 by Tom Burrows, on Flickr {} IMG_20171224_150959 by Tom Burrows, on Flickr {} IMG_20171215_222646 by Tom Burrows, on Flickr {} IMG_20171209_155954 by Tom Burrows, on Flickr {} IMG_20171125_145708 by Tom Burrows, on Flickr {} 38209327932_8ce7b0136d_o by Tom Burrows, on Flickr {} 38186401136_17bfcdb8ee_o by Tom Burrows, on Flickr {} 26464434629_a0266fb1e6_o by Tom Burrows, on Flickr {} IMG_20171021_145442 by Tom Burrows, on Flickr
