Fabia VRS
Thread in 'Misc for sale' started by Matts Turbo'd, Mar 30, 2020.
  1. Matts Turbo'd
    Matts Turbo'd Member
    North London
    Skoda Fabia VRS 2005
    I’ll start with the specs
    Before I bought it it had
    Solid flywheel conversion
    Pd150 injector upgrade
    Decat but still has centre and rear silencer
    Polybushed front arms
    decent bit of service history
    I bought this in September with a unknown cooling issue which turned out to be headgasket
    Had a full top end rebuild with
    PD150 headgasket and headbolts
    New injector seals
    All new gaskets and seals through out the top end (inlet, exhaust, cam seals, fuel pump gasket, thermostat gasket, rocker cover gasket. Basically everything new
    Head was skimmed and pressure tested before refitting
    New cambelt kit and water pump was fitted with genuine coolant when the headgasket was done along with an oil change using castrol oil
    Have pics of the top end rebuild
    I used it for 3k and noticed an oil leak from the turbo pulled the turbo off and found the turbo was knackered
    Had a brand new PD150 turbo less than 1000 miles ago with genuine oil return and gasket
    Was mapped to approximately 200 bhp very quick car potential to go further
    Today it’s had 2 new budget tyres on the front and a second hand intercooler as the original had a hole in it somewhere
    It does have a few niggles
    Both front fog light lenses are broken
    Scrape in the rear bumper
    Would benefit from an alignment as pulls slightly to the left
    It’s a very quick car cleans up alright the interior is pretty dirty previous owner was a mechanic I’ll attempt to clean it but not sure how well it will come up
    Comes with the private plate valued at 700 pounds
    Please bare in mind the amount I’ve spent having everything done turbo was 350 quid on its own and has warranty for 10 months
    Can transport anywhere in the uk for 1 pound a mile one way
    3F255D27-6E14-4438-B8D5-0C09914EE5F3. 251BBBA4-BC4D-47B6-B026-2A8CB00483C1. F2F76DCC-9809-414E-BFA1-A1DC82F45C9A. D980A2C3-1B93-4D6B-A21F-1C9FCDF2EDE0. 0FF5B131-7741-43B5-B398-F2FD94E3D454. A10B9187-7D4B-4BA8-9C18-7718AA85E8B8. C0676ECA-FDEE-4C4B-AE8C-4E26E8482A17. 12822543-97F7-4E66-AC42-9C2512D40234. CA205452-D6FE-4A7B-B456-537BDB3654A8.
  2. driftasx
    driftasx Member
    north london
  3. Roofless_
    Roofless_ Active Member
    Sevenoaks
    Does it pull like a train?
  4. Matts Turbo'd
    North London
    Sorry 2500 Ono
