Faces loose in the lip?
Thread in 'Technical Questions' started by Anto195, Mar 30, 2020.
  1. Anto195
    Anto195 Member
    Dublin
    I was trying a 3.5 inch lip onto my wheels earlier to see what the fitment would work out like, I had this lip at home and hadn't used it before, the face is very loose in it, should it not be a tight fit against the centre diameter? Or do different lips have a different diameter?
    Thanks
    IMG_20200403_195511.
    IMG_20200403_195420.
    IMG_20200403_195328.
    #1 Anto195, Mar 30, 2020
  2. Anto195
    Anto195 Member
    Dublin
  3. joelhachiroku
    joelhachiroku Member
    Christchurch new Zealand
    Have you tried putting all the bolts in so it centers the face up in the lip correctly?
    That gap shpuld be fine once its all bolted and sealed
  4. Anto195
    Anto195 Member
    Dublin
    No I haven't tried them all in yet, I'll give it a shot today, but the gap seems pretty even the whole way around even with two holding the face in,
    From any I have split before, which isn't many, I thought the face should be a dead tight fit against that centre circumference
  5. joelhachiroku
    Ill check my kfs tomorrow but im pretty sure the faces pretty much fall in place.
  6. Anto195
    Anto195 Member
    Dublin
    Thanks I'd imagine they should be, the face was tight coming out of the old ones but I'm not sure if that's due to corrosion, even still I don't think the gap should be that big
  7. joelhachiroku
    All my wheels bolted together are the same. Just clean with a wire wheel so all the surfaces are spotless you should be sweet. And make sure the rubbers on the valves are in good condition
  8. Anto195
    Anto195 Member
    Dublin
    Thanks man, I'll build them all up and see how I get on, of you get the chance you'd you send on a picture of the gap on yours
  9. joelhachiroku
    My cameras broken man. Sat it down on a bolt and not even that hard ‍♂️
