Fitted rack spacers but no time to get tracking done
Thread in 'Drifting Chat / Pictures / Videos' started by DENZIL7, Sep 10, 2013.
  1. DENZIL7
    DENZIL7 Member
    Hey I have just fitted 4mm rack spacers to my e36 but don't have any way of getting the tracking done before a track/drift day at coombe on Friday is this gonna cause me any major headaches if I'd do a day with the tracking slightly out
    Thanks in advance :)
  2. hoagy5
    hoagy5 Member
    Burlescombe, Devon
    If you have adjusted the track rods into the ends by 4mm you should be close enough till you can get it set up properly, have a good time at Coombe but be careful on Quarry!
  3. GB / John
    GB / John NDC Runner Up 2012
    Washington / Newcastle UK
    I always done mine by eye, then put steering wheel back on centrally if it was out.
  4. DENZIL7
    DENZIL7 Member
    Ill adjust it up tomorrow and then get it setup
    Do they really make a difference though as if I'm toe on 4mm don't this just cancel out the spacers #confused
  5. spaniel
    spaniel bigballs small brain
    I had to wind mine in more than 4mm to get them looking right. Just keep having a play and do it by eye.
    Dont try going out without adjusting them you will be all over the place
  6. dan_gsxr
    dan_gsxr Member
    i did mine last night on the drive, i just matched them to the length of the old one when bolted up and the car drives spot on!
    might not even get it tracked up!
  7. DENZIL7
    DENZIL7 Member
    Track rod end bolts apeared to be seized so ill have another go tomorrow
  8. Dex
    Dex kut!
    Clogsville
    yea they tend to do that on e36's heat the cunts up real good!
  9. DENZIL7
    DENZIL7 Member
    Gonna take it somewhere local to get it sorted
