For sale volvo 360 turbo 2.3 very quick ££££'s spent mot'd and taxed 2900 maidstone
Thread in 'Drift cars for sale' started by joeshutt1988, Sep 16, 2014.
  1. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
    HERE FOR SALE IS MY VOLVO 360 1988 IN DARK GREYIT HAS 1YRS MOT AND TAX TILL JANIT HAD TWO ADVISORYS ON ITS MOT WHICH IT HAD MONDAY , SLIGHT PLAY IN NSF BEARING , AND SLIGHT TEAR IN BALL JOINT GAITER. SO NOTHING WRONG WITH IT AT ALL !IT IS VERY QUICK AND THE TURBO SPOOLS VERY QUICK AND HAS A VERY HARD PUNCH ! ITS ABOUT 230BHP AT 0.7 BARIT CAN BE RAN AT 1.2 BAR SAFELY WHICH WILL PRODUCE A LOT MORE POWER BUT WILL NEED A FLYWHEEL SKIM TO DO SO AS ITS AT ITS LIMIT ON THE CLUTCH NOW.HERES A SPEC PLEASE TAKE THE TIME TO READ IT !No rust on the car
    Small dent on osr corner by boot
    Pretty clean all over though !
    5 link rear axle conversion , so no leaf springs!
    No oil leaks smokes etc runs great
    Welded diff
    13 inch wide mini lights all good tread , could do with balancing
    New brake servo and reservoir seals
    Exhaust heat wrapped
    Sunroof removed carbon panel fitted in place
    Perspex front windows with sliders
    Custom made rear diffuser
    Basic alarm fitted to vehicle
    2.3 740 turbo engine
    Front mount hidden intercooler
    Turbo is td04 16
    Transporter friction plate as 230mm and stage 2 volvo 740 pressure plate.
    Larger air mass meter
    All new ignition system
    Injectors are cosworth greens
    Walbro fuel pump 255lph
    Adjustable lower and castor arms
    Modified hubs for extra lock
    new pads discs track rod ends and ball joints
    S13 top mounts
    Full custom coilovers with damper adjuster
    Hydraulic handbrake
    Super-chipped ecus
    Onegawa snap off steering boss and sparco wheel
    Full custom exhaust system with bike can , unbolts in sections easy
    All wiring and ecus located and hidden together , still has glove box too !
    Boost and oil pressure gauge
    All lights and gauges work fine
    Adjustable boost controller from dash
    Two new buckets and 4 point harnesses adjustable on bolted mounts
    Interior stripped and flat lightweight door cards fitted
    Battery re-located in car
    The car has done 71000 miles
    NO MESSERS OR TEST PILOTS ! I GO ON HOLIDAY ON THE 23RD SO I NEED IT GONE BY THEN CAR IN KENT ANY QUESTIONS OR VIEWING 07805635531 JOE​
    - - - Updated - - -
    <a href="http://s1216.photobucket.com/user/joeshutt/media/6262BE73-E2B8-43FF-9C1B-BC541EBDC21F_zpspehg5sdi.jpg.html" target="_blank"><img src="http://i1216.photobucket.com/albums/dd378/joeshutt/6262BE73-E2B8-43FF-9C1B-BC541EBDC21F_zpspehg5sdi.jpg" border="0" alt=" photo 6262BE73-E2B8-43FF-9C1B-BC541EBDC21F_zpspehg5sdi.jpg"/></a>
  2. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
    - - - Updated - - -
    - - - Updated - - -
  3. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
    - - - Updated - - -
    - - - Updated - - -
  4. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
  5. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
    - - - Updated - - -
  6. shelbz S14A
    shelbz S14A Active Member
    essex
    How much is it buddy sorry if I missed it ?
  7. TurboTinkerer
    TurboTinkerer New Member
    Chester
    That looks sweet! glwts
  8. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
    2900 Ono mate sorry if it's not clear
  9. chris-s13
    chris-s13 Member
    scotland
    2900 a think mate
  10. Jack-J
    Jack-J Member
    South of B'ham
    That car looks awesome!
  11. shelbz S14A
    essex
    Ok just seen the full title my I phone was cutting the screen
  12. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
  13. saihaynes
    saihaynes Member
    Swindon
    Looks great, glwts
  14. joeshutt1988
    joeshutt1988 Member
    kent ENGLAND
    Car has sold I'm afraid . Thanks
