For Sale Forged 3S-GE Beams black top block
Thread in 'Parts for sale' started by JZZ30, May 8, 2017.
  1. JZZ30
    JZZ30 Member
    S.-W. Germany
    Good day folks.
    Due to a change of plans I am am skipping on forced induction looking to swap my forged beams black top block for a standard block.
    The only reason is that I now want to compete in a national touring car series where non stock forced induction is prohibited.
    My block as available for a swap:
    Precision bored out to 86.5mm
    Honed to 0.1mm piston to wall clearance
    deck skimmed
    Main Bearings - ACL Race Bearings
    Thrust Bearings - ACL Race Bearings
    Lower connection Rod Bearings - ACL Race Bearings
    Eagle forged connecting rods (from 3S-GTE)
    Wiseco 86.5mm forged pistons from 2JZ-GTE machined to fit oil squirters and larger 3S-GE valves and diff. valve angles.
    Can also supply a 1.8mm Apexi metal cylinder head gasket.
    Final comp. will be at approx. 9.6:1 (standard head gasket) or 8.4:1 (with the 1.8mm Apexi head gasket)
    Build block totaled at about £1'400
    Looking for a clean low mileage standard block (complete assembly - crankshaft, rods, pistons) as partial exchange:
    Price £800 (+£140 for Apexi head gasket)
    Or
    Cash sale:
    Price £1'100 (+£140 for Apexi head gasket)
    Would also consider an aftermarket exhaust header (HKS, Toda or similar) as part ex.
    I could also supply a used Greddy cast manifold, a freshly balanced Garrett GT2871RS turbocharger, new 850ccm Injectors and 3" pipe and silencers to build a full 3" exhaust with vband clamps (downpipe already tig welded).
    If you are interested please don't hesitate to contact me for questions or further details
    #1 JZZ30, May 8, 2017
  2. JZZ30
    JZZ30 Member
    S.-W. Germany
    Would also remove custom pistons and eagle connecting rods and sell separately:
    4 Pcs. 86.5mm custom milled 2JZ-gte Wiseco piston incl. pin and Piston Rings for 0.10mm wall clearance
    They fit stock or 3s-gte connecting rods
    Price £380
    Set of eagle 3s-gte forged H-beam connecting rods to fit stock or forged 3S-ge pistons or the above
    Price £300
    Apexi metal head gasket 1.8mm to reduce compression (to 9.6:1 with stock internals or 8.4:1 with the setup above).
    Price £130
  3. JZZ30
    JZZ30 Member
    S.-W. Germany
    Here you go with some pics of the block and internals. Please notice the high quality new hone marks (overbore +0.5mm, 0.09mm piston to wall clearance).
    IMG_20170517_180443. IMG_20170517_180626.
    2JZ-gte pistons with modified valve pockets to suit larger diameter 3s-ge black top valves, diff. valve angle and VVTI - and modified to suit oil squirters
    IMG_20170517_180549. IMG_20170517_180856.
    3s-gte H-beam Eagle con rods with ARP 2000 bolts and ACL race crank journal and big end bearings
    IMG_20170517_180836. IMG_20170517_180842.
    block assembly - skimmed deck..
    IMG_20170517_181046.
    Everything yellowish is fresh motor oil left over from assembling...
    Pistons will clear valves with factory head gasket and VVTI.
    They might even clear high lift cams with a thicker metal head gasket.
    #3 JZZ30, May 18, 2017
  4. JZZ30
    JZZ30 Member
    S.-W. Germany
    Pistons have been removed from block as I am keeping the block and rods.
    Still for sale and available for a quick dispatch:
    4 Pcs. 86.5mm custom milled 2JZ-gte Wiseco piston incl. pin and rings for 0.10mm wall clearance
    Price £350
    Price £120
    Greddy Altezza 3S-GE cast manifold (T2/T25/T28 flange) in good shape
    Price £100
  5. The Bom3
    The Bom3 New Member
    Ireland
    Are these parts still available??
