Hi all, I was moving house and just clearing out my garage. I no longer have a Datsun only a rx7 so these parts are of no use to me any more. forum rules state i need to put a price up so will put up a price but open to offers on all I have 3 dead t28 turbo's - £20 each (could be t28r's) not sure how to tell, it's been a while since I ran them Sr20det exedy hyper single plate clutch cover and flywheel no friction plate as no meat left on it. Surfaces need a clean £100 new friction plate can be bought from rhd japan, exedy, bidjdm, dw maybe. Would work out cheaper than even buying a second hand exedy hyper single clutch kit. Sr20det ORC single plate clutch. Few mm's left on friction plate (see pic) On the clutch cover the pressure plate fingers are dead but these can be replaced as they have individual allen key heads and screws. again all surfaces need a clean £70 Place add postage costs on top thank you
Turbo part numbers it appears 2 of them are ball bearing and the other one is stock t28 All that matters is the garret number, everything else just confuses matters 466541 = ball bearing 466543 = bush bearing for the second bit of the number -001 = S14 turbo (no splitter between wastegate and turbine exit) -002 = S15 turbo (splitter between wastegate and turbine exit)
