Geometry Over centering issue
Thread in 'Technical Questions' started by CJRdrift, Nov 9, 2013.
Tags:
  1. CJRdrift
    CJRdrift Member
    I have tried several setups on my geommetry throughout thgis year from mitto daily, to just track, the track & street set up worked ok but then had someone put there own settings on my car and it works ok when throwing it in without being on the wand or initiating with a clutch kick, i can just sway it into a skid but when going on full lock its a cunt to pull back so is going over centre im just wondering isitworth going back to the mitto settings I had or leave this very stable setting on my car but just put my DW lock stops back on.
  2. 200sx_
    200sx_ PS13 x TD Power
    Would help if you mentioned what lock mods you have?
  3. CJRdrift
    CJRdrift Member
    Im running every DW arm camber, caster, toe etc inc geomasters, off set tension and offset rack spacers on BC coilovers, and tein rods & ends, whole car was built this year from new.
  4. MJG
    MJG Active Member
    Reduce your caster and run a lower scrub radius (higher offset wheels)
  5. PhilMorrison
    PhilMorrison Driftworks Owner
    Staff Member
    As Mike says, castor is usually the tripping point with overcentering.
  6. diamondsink
    diamondsink Kyouto Drift
    Or move the rack a small amount.
  7. CJRdrift
    CJRdrift Member
    Thanks This has helped massivley just need to track test it now, Im starting to learn more about geometryeachday lol well understand bits anyway haha, Thanks guys
  8. CJRdrift
    CJRdrift Member
    i been suggested this by having a mate remake one but already have offset spacers and dont need stupid lock really so id rather loose a little lock and be safer not over centering and get used to it again. cheers dude,
