Gk tech lock adaptors s13
Thread in 'Parts for sale' started by djdobson, Aug 18, 2016.
  1. djdobson
    djdobson Member
    In really good condition I stole the description off of gk techs website. Cheap option for more lock on an s13. Missing a castle nut but they only cost a quid
    £140 posted
    The GKTECH roll center correction kit is CNC machined from 7075-T6 aluminium and provides 40mm of roll center correction, 40mm of bump steer correction and also re-positions the steering arm to increase steering lock. The roll center correction kit bolts up to the bottom of your standard knuckle and can be removed with no ramifications at all. Circa 60 degrees of lock is achievable without rack spacers once the factory LCA lock stop is removed but if you're running lots of camber or caster using our offset rack spacers is a good idea to avoid steering bind. By far the cheapest way of getting both roll center correction and lock.
    NOTE: These will increase camber as it pushes the bottom of the wheel out 25mm so best to only use with adjustable camber tops.
    Vehicle Compatibility:
    - Nissan 180sx
    - Nissan S13 Silvia
    NOTE: if you are running S14/S15 knuckles in your car then you will need the S14/S15 RC correction kit as these are knuckle specific
    Sent from my SM-N910F using Tapatalk
  2. djdobson
    djdobson Member
    Sold!!!
