Greddy Turbod Mx5
Thread in 'Project Cars and Builds Threads' started by RyanR33, Dec 5, 2012.
Tags:
  1. RyanR33
    RyanR33 Member
    Mx5 Turbo ***Greddy***
    Allryt Folks had this car awhile now i got it as a fresh import totally standard and made it my own over time comments welcome
    1990 Mazda Mx5 Eunos Roadster
    1.6 16valve DOHC
    Fully adjustable Cusco Zero 2 coilovers
    Rs Aizawa vented passenger side headlight cover
    MazdaSpeed Tsi (turn signal intakes)
    Genuine Mazda OEM type 1 front Splitter
    Greddy Bolt on turbo Kit
    Greddy Block Manifold
    Vortech Fuel Pressure Regulator
    Tdo5 Turbo
    After market Oil catch can (unsure of make)
    Peco Cat back exhaust system
    Hks Decat
    Mazdaspeed stage 1 uprated clutch
    lightend Flywheel
    Wiseco Steel headgasket
    Sparco Dished Drift wheel
    H4 Halogen upgraded Headlights
    Brand New Mazda Soft top
    Fibreglass Ductail Spoiler
    Bonnet Raised 20mm at rear
    Hks Induction Kit
    Custom Hardpipe from turbo to inlet
    Full Respray in Mazda Silver 3L
    15 Inch Rare Oz Chronos
    Baileys Dump Valve
    Black and yellow leather seats
    Razo Pedals
    Rocker cover painted Honda Eternal Blue
    Oil Catch Can
    cheeky shot
    Next plan is front Mount
    and XxR 527s
    Always said would be happy with a Mx with 200bhp so need to get there not far to Go..
    #1 RyanR33, Dec 5, 2012
  2. oli_the_thread
    that looks really nice! I'd never have thought a chunky 5 spoke would work, but they really suit it!
    What management are you running/planning on running?
    Also I'd put the rear of the bonnet down, that actually increases pressure and hinders airflow from under the bonnet as opposed to help, a turbo blanket would be a better idea if you're worried about temps
  3. Supra Gaz
    Supra Gaz Member
    Looks nice and clean, cool wheels too.
  4. RyanR33
    RyanR33 Member
    Not running any management at all just running stock ECU with timing retarted 6degres before tdc would look into management at some stage very expensive tho
  5. oli_the_thread
    If your handy with wires you can pick up a mega squirt for sub £300 as you'll really struggle to get 200bhp without standalone, even an emanage blue would struggle to get to 200.
    Best of luck though!
  6. hoodedreeper
    hoodedreeper Member
    Expensive but VERY worth it :)
    Very nice 5 :)
  7. r3k1355
    r3k1355 Well-Known Member
    Are you still running the carbon canister, can get rid of that right away.
    You might wanna look at removing the PCV valve too, they can't hold boost and you might be leaking boost into the cam cover using that :eek:
    How much boost is it running, the Vortec unit can't handle much more than about 5psi IIRC.
  8. RyanR33
    RyanR33 Member
    Iv heard of the megasquirts youll need to get a map aswell surely?
  9. RyanR33
    RyanR33 Member
    Carbon canister? Pcv valve
    Running .7- .8 goes well just want it to go abit better lol
  10. oli_the_thread
    Doesn't really matter what you've got it'll need mapping, even just running an afpr you'll still need to adjust it using an far gauge which is in a way 'mapping' although much less accurate
    At least with mega squirt you'll be able to get a relatively genetic map and adjust it to suit.
    The difference between running on an afpr or a piggyback/standalone is night and day.
  11. RyanR33
    RyanR33 Member
    see i live in Northern irealnd and last time i looked into management i heard i would have to go to england to get it mapped so thats another reason why i didnt get it done as there was no1 to map it over here but its seriously hard on fuel need to do something lol
  12. oli_the_thread
    No chance! The amount of nice cars coming out of Ireland and the fact it has its own drift series says to me there must be plenty of tuners over there, find a local reputable tuner and see what they recommend, no point buying megasquirt if your local tuner won't work with it. Have you tuned it with an AFR yet?
    Edit: quick google returned this, it may be over 5 years old, but I'm sure there will be plenty of places still open to support what you need, find one you trust/near/cheap whatever's for you and talk to them about what they recommend. A lot of FI mx5s use MS because its so cheap and user friendly that with a bit of research and common sense you can do a lot of the work yourself then usually get someone to fine tune your base map which means less time on the dyno/road which means less time your paying for!
    http://www.toyotagtturbo.com/forums/showthread.php?19-Ireland-Northern-Ireland-Rolling-Road-A-Z
    #12 oli_the_thread, Dec 5, 2012
  13. RyanR33
    RyanR33 Member
    No mate havent had any afr work or anything at all done the turbokit was fitted and timinig was set thats about it then hardpipe
  14. oli_the_thread
    no wonder, its probably throwing away fuel for fun atm and overfueling. Get an AFR gauge in there and have a play around with the AFPR until you're getting a decent reading, although depending on which AFPR you've got depends how it will run.
    I'd also suggest you run through this before going much further, you dont wanna do your engine any damage
    http://miataturbo.wikidot.com/
  15. RyanR33
    RyanR33 Member
    yeah mate its definatly using too much Fuel i no that the exhaust is black aswell lol i really need to get it sorted it tho i dont think it will be doing damage as its done 20.000 hard miles turbod of the road for the bad weather at the minute so plenty of time to sort it all out i think iv fallen in love with Grid Drifts aswell so might have to get a set :)
  16. RyanR33
    RyanR33 Member
    Wana fit the oil cooler to this this week any idea about mounting it outside the front bumper and how legal it is?seen it on net and think looks pretty cool
  17. RyanR33
    RyanR33 Member
    Magnecor Leads
  18. RyanR33
    RyanR33 Member
    Cheers mate
  19. RyanR33
    RyanR33 Member
    New Wheels
    15X7 Rota Gt3s
    forgot i had The Mazdaspeed TSIs in the Garage put them back in aswell.
  20. richy d
    richy d Active Member
    How the hell has that thing covered 20,000miles at 8psi on just an afpr and no intercooler??
    looks good either way,get some management on it though.It will be worth it.
