Gtr Seats In To An S14
Thread in 'Technical Questions' started by S14JON, Feb 13, 2009.
  1. S14JON
    S14JON Member
    Southend
    Hey guys any one out there tell me what needs to be done to fit R32 GTR seats/rails in to an s14, i under stand that 3 of the 4 holes line straight up and the 3rd one needs an extra bracket welded on to reach, which should be about 30mm.
    Is this right as this was the only info i could find on the sxoc but was for an S13 :confused:
  2. Midlands_Si
    Exactly the same with an S13 as a 14 dude - as you say - small extender plate, job done :)
    You don't need to weld anything, just get a bit of bar, and a nut and bolt :) Drill 2 holes in the bar, bolt one end with the nut and bolt to the seat subframe, and use the existing seat bolt on the other one to bolt it to the floor :)
  3. gweedo
    gweedo Member
    Vilnius, Lithuania
    You just can take of the gtr mounting bracket and weld the s14 bracket, that' s what i' ve done, then it fits perfectly
