hello from az with a 1jz sc300!
Thread in 'Drifting Chat / Pictures / Videos' started by ruby1j, Oct 5, 2012.
  1. ruby1j
    ruby1j Member
    hi guys i have a 1jz sc300 that im currently building up. im not building it up to be a drift car but i am building it to the point where i can drift it :D currently the car is down :( the twin turbos blew up on me last week so im currently piecing together a single turbo kit. mods are as followed on the car:
    -full 3 inch stainless exhaust (y-pipe too)
    -tein flex coilovers
    -titan cam gears
    -stage 3 clutch on w58
    -greddy fmic
    -supra bbk in front
    How do you post pics?? well heres some vids:
    had a bad boost leak on the 2nd vid. well thats it for now, will be updating this thread as i go! cheers :smokin:
  2. smokindrifter
    smokindrifter Member
    just noticed there's a guy sneaking around the back of the car oiling your tyres ! :D
  3. BrummieJDM
    BrummieJDM Member
    Love soarers :)
  4. ruby1j
    ruby1j Member
    only because we wanted massive smoke :D but unfortunatly it didnt work :/
  5. ruby1j
    ruby1j Member
    wow so i havent updated this thread in a while! WELL to start off i started my single turbo build. i will be using a holset hx35 for the ease of drifting :D
    the disassembly begins
    oh boy!
    twins off...what a pita!
  6. ruby1j
    ruby1j Member
    then it led to test fitting the manifold
    and then i just couldnt wait...had to do a mock fit!
  7. ruby1j
    ruby1j Member
    then i had to put the fuel rail kit on...had to take off the throttle body and the iac valve to get access...this was not an easy job. lots of patience required
    finally got the damn fitting on
    fitting on return line. i plan to make this a push lock hose in the near future
    and this was the hard part! On sc's, unlike mk3's, it is just plain firewall. there is no step or anything to mount the aeromotive fpr! so i ended up zip tying it (yes, im a zip tie master ;) to some hardlines. hardly any movement so it should work :D
  8. Rossc0
    Rossc0 Diesel Skidder
    Impressive...
  9. ruby1j
    ruby1j Member
    i had a boost leak :( didnt spool as fast as it should on twins
  10. ruby1j
    ruby1j Member
    now to continue :D
    mock fitted the adapter plate on since my manifold is a t4 and my turbo is a t3
    heres my set up. hks 50 mm wastegate and a driftmotion manifold
    so i went ahead and mounted everything but found this out :(
    the head of the wastegate is in the way of my downpipe going in!!! and unfortunatly i do not knw how to weld so its off to the shop to finish up with downpipe, lc-1, and intercooler piping install
  11. ruby1j
    ruby1j Member
    another pic of my beautiful 1j lol. yes, i love my 1j soooooooooo much! HAHA
    AND HERES HOW ITS SITTING CURRENTLY. IT WILL BE HEADED TO THE SHOP WEDNESDAY!
  12. Rossc0
    When are you going to drift it?
  13. ruby1j
    ruby1j Member
    pulled the 1j out to do a little spring cleaning
    http://s1224.photobucket.com/user/w...006-D284E050E0B5_zpsdyjgp56f.jpg.html?filters[user]=112416149&filters[recent]=1&sort=1&o=17
    before and after of the engine bay
    to now this
    gold flakes on timing cover
    now the engine bay looks like this with the motor in it
    i installed:
    -new timing belt
    -15 psi wastegate spring
    -650cc sard injectors
    -new front main seal, cam seals, cleaned everything up
    -walbro 400
    -emanage ultimate
    will post updated pics a little later. these pics were taken a few weeks ago. car is now running and driving. im looking for a good map for the emanage ultimate. im running 650cc inj, holset hx35, walbro 400, aeromotive fpr, stock cams. anyone have a good map? plan on running 19psi with my boost controller, 15 psi with just wastegate
  14. ruby1j
    ruby1j Member
    gonna get my diff welded here soon and when i get a good map on the emanage, gonna start taking it out to the track and shred tires
  15. C1arke
    C1arke Member
    Love the car. Hope I can get the cash to do a hx35 swap
  16. driftyj
    driftyj Member
    Lovely Soarer there mate
  17. ruby1j
    ruby1j Member
    its fairly cheap man. i got my holset for $100.
    just lowered my car last night again. sry for horrible pics, it was getting late and just snapped a few quick ones
    from from this:
    to this:
  18. C1arke
    C1arke Member
    More low lows for the hoe hoes
  19. ruby1j
    ruby1j Member
    maxed out on the rear. tein mono flex dont go too low :( need better wheels
  20. C1arke
    C1arke Member
    Wats the speck on the wheels and you have to role the arches
