I have recently brought a 1jz big single turbo converted s14 that has a few running problems I’m hoping people can point me in the right direction to fixing them Hunts on idle when cold started and occasionally cuts out (stops hunting and cutting out once warm) When the car has been driven or ran for a while and is up to temp the car will not re start if it’s turned off unless you unplug the temp sensor Any help would be appreciated
