Help!!!!! (ignition problem)
Thread in 'Technical Questions' started by C17 LUK, Mar 25, 2011.
  1. C17 LUK
    C17 LUK Member
    bristol
    basically swapped the ignition barrels around from my s14a's because i had earlier swapped the doors and boot over because they were in better condition.
    so because it would be a ball ache to change door locks over i decided to do ignition and boot locks. boot lock done happy days works sweet then i come to do ingnition swap it all around fit it up with the immobiliser thingy swapped over aswell go to start the car and all i get is the car cranking over?????
    wat am i doing wrong?
    so in short
    swapped ingnition barrels and immobiliser sensors over so i use the same key as the doors.
    sorry for the jiberish but realy doing my head in!!!!
  2. wilton1851
    wilton1851 Member
    n.ireland
    Did you transfer NATS system and ECU over too?
  3. C17 LUK
    C17 LUK Member
    bristol
    where is the nats system? and no havent changed ecu that was my next attemp at it?
  4. wilton1851
    wilton1851 Member
    n.ireland
    Can be in the passenger footwell or inside the rear quarter (again, on the passenger side of a UK car).
    The wiring is always in the passenger footwell though, above the ECU.
