Help needed
Thread in 'Technical Questions' started by Mathew Mower, Jul 13, 2020.
  1. Mathew Mower
    Mathew Mower New Member
    Cork
    94CC438D-3C8C-4674-BDC0-1F047B7D7A5F. Hi all,
    Im having trouble Removing a tuner style lug nut that has decided to round itself, any suggestions to removing the stubborn nut without me damaging the alloy anymore??
    cheers.
  2. Supra Gaz
    Supra Gaz Member
    West Sussex
    I faced this very problem removing some crappy nuts left on by a previous owner of one mine.
    Pop a couple of decent wheel nuts in to share the weight of the wheel onto other nuts, I heated the nut lightly to make it less brittle and then used a over side Allen key type fitting and smashed it in with a big hammer, then I gently turned it off. Insert a stupid amount of swearing between these steps. It worked, but I wouldn't want to do it again.
  3. Mathew Mower
    Cork
    cheers for the info!! I fitted a 13mm Allen key and whacked it in, but it just rounded again.. I’ll try get a 14 and repeat with abit of heat.. I’m at the point where if the alloy gets damaged more I’ll just have to buy another one!!
  4. oscar
    oscar Member
    Whack a Torx bit in there instead of an Allen key...
  5. Mathew Mower
    Cork
    cheers Oscar I’ll give that a go!!
