Help Please
Thread in 'Technical Questions' started by smokebillowing, Mar 12, 2013.
  1. smokebillowing
    smokebillowing Active Member
    West Sussex
    Hi all, My daily is an s13 with following spec:
    series 1 rb25
    rb25 box
    custom prop
    s14 rear subframe
    offset allu bushes
    adjustable rear toe arms
    adjustable read camber arms
    s14 driveshafts
    5 stud hubs
    4.1 diff welded
    s14 rear arms
    driftworks cs2's
    10j rear wheels and 255 rear tyres
    etc etc...
    The problem I have is rear end related... When i make a turn (anything under mph really) it makes a clunking noise and the car will kangaroo like i just started driving making me look like a dickhead... If I load the diff up its fine, like put my foot down more and take the corner faster its okayish but still clunks a bit. occasionally i get the standard drive-shaft pop associated with a welded diff so its not that... I'm thinking backlash on the diff? anyone else wana chime in?
  2. smokebillowing
    West Sussex
    Also get wheel hop if i spin the rear wheels off the power ie. boosting second... if i depress the clutch round a corner it sounds like the diff is literally rattling round in the case...
  3. Burger93
    Burger93 Member
    Grimsby
    Badly welded diff? Bushes going? Could be something as stupid as top mount/strut tops? It could be many things mate you just need to brace the cold get it up in the air and have a good look mate.
    Cheers
    Josh
  4. smokebillowing
    West Sussex
    Done that... It's not bushes or strut tops. Ive replaced everything but the diff.. I was hoping someone else has had the same problem...
  5. RobinvdH
    RobinvdH Member
    Check the diff? if the welding has come loose or something you'll get some weird clunks/locking/popping/silly stuff.
    Your driveshafts are fine?
  6. smokebillowing
    West Sussex
    I think so... I jacked the car up earlier and there's a shit ton of play/backlash. New diff time I think...
  7. RobinvdH
    RobinvdH Member
