Help with connection Bee*R to 1zz-fe
Thread in 'Technical Questions' started by PaulXZY, Oct 8, 2019.
  1. PaulXZY
    PaulXZY New Member
    Hi i need help with connection bee*r to my 1zz-fe ecu. I have problem with get the rpm signal.
    I tried connect it to TACH on ecu and IGF but with no results. I don't cut so far ecu wires i only stick the wires from the side of pins.
    I connect:
    Red wire to 12V battery positive
    Black to battery negative
    Green to NE+
    Yellow to TACH and next to IGF but device don't read the signal
    Of course the Bee*R is the original one, 30th anniversary with switches
  2. PaulXZY
    PaulXZY New Member
    ECU pinout
    DIAGRAMS_ENGINE_ECM_GUIDE1.
    DIAGRAMS_ENGINE_ECM_GUIDE2.
