For Sale Holset HX40 16cm T3 650bhp+ Turbo - Rare 60mm Billet Compressor Wheel
Thread in 'Parts for sale' started by Nite_Shayde, Feb 15, 2020.
  1. Nite_Shayde
    Nite_Shayde Active Member
    The Big Smoke
    For sale is a used Holset HX40 with the following specs:
    - 60mm billet inducer, 86mm exducer 7+7 blade compressor wheel (largest factory HX40 compressor wheel available)
    - 76mm inducer, 64mm exducer 12 blade turbine wheel
    - 16cm T3 internal wastegate turbine housing (will need welding shut)
    Could do with a proper clean or freshening up - turbine housing has rust as you can see, but that's cast iron for you, always inevitable. The (factory) paint on the compressor housing doesn't look great anymore, and there's some corrosion present on the once shiny aluminium areas. Part of the compressor outlet flange is a bit mangled, so will need sorting or simply cutting off and a new flange/elbow welded directly on. It's an honest used turbo though, not just blasted from top to bottom and made to look good (but actually junk) like turbos from a certain other seller...
    No axial play in shaft. Minor radial play (typical and very normal). No damage to compressor wheel or turbine wheel. Spins freely.
    Would like to get £285 plus postage for this.
  2. Nite_Shayde
    The Big Smoke
    Still here...
  3. Nite_Shayde
    The Big Smoke
  4. Nite_Shayde
    The Big Smoke
  5. Nite_Shayde
    The Big Smoke
