For Sale Holset HX40 18cm T3 650bhp+ Turbo - Big 60mm Inducer with Rare 10 Blade Turbine
Thread in 'Parts for sale' started by Nite_Shayde, Feb 15, 2020.
  1. Nite_Shayde
    Nite_Shayde Active Member
    The Big Smoke
    For sale is a used Holset HX40 with the following specs:
    - 60mm inducer, 86mm exducer 7+7 blade compressor wheel (largest factory HX40 compressor wheel available)
    - 76mm inducer, 64mm exducer 10 blade turbine wheel (higher flow over the more common 12 blade turbine)
    - 18cm T3 internal wastegate turbine housing (will need welding shut)
    This is in overall great condition and one of the better spec HX40s out there with the big compressor wheel and rare 10 blade turbine. As you can see the entire turbo was painted green - typical of Cummins on certain engines from the factory, not a bodge job done in someone's shed. There are marks and light corrosion here and there of course - it's an honest used turbo, not just blasted from top to bottom and made to look good (but actually junk) like turbos from a certain other seller...
    No axial play in shaft. Minor radial play (typical and very normal). No damage to compressor wheel or turbine wheel. Spins freely.
    Would like to get £295 plus postage for this.
  2. Soarermike91
    Soarermike91 Member
    South england
    Looks like it's of a military vehicle
  3. Nite_Shayde
    The Big Smoke
    Very possible
  4. Nite_Shayde
    The Big Smoke
    Still here...
  5. Nite_Shayde
    The Big Smoke
  6. Nite_Shayde
    The Big Smoke
  7. Nite_Shayde
    The Big Smoke
  8. Nite_Shayde
    The Big Smoke
