How To - DIY Flocking guide
Thread in 'Technical Questions' started by McLarenboy, Oct 25, 2011.
  1. McLarenboy
    McLarenboy Member
    Belgium
    Upon request in my other thread i've started this one to give you an overview on what you need to do your own DIY-flocking.
    I'll start with some points to avoid any misunderstandings:
    - I decided to scout the web to understand how flocking works because in Belgium and Holland they charge at a minimum 170 quid for flocking a dashboard. Which is a ridiculous amount of money which I was not willing to pay. I had a guy who did some flocking for me (85 quid for a dash) but he decided to stop so I had no alternative left.
    - Everything which you’ll find below is the result of google and youtube.
    - The end result cannot be compared to professional flocking equipment, hence the term DIY. For one thing I cannot buy the shortest of fibres because the company wants a minimum order of 50kg (Home PIN Floc)
    - flocking a part is applying positively charged fibres which are in a container to the negatively charged part which is glued and being grounded. When the + en – come together they generate an electrostatic field in which the fibres will uniformly dig into the glue. The more powerful the field is, the greater the distance between + en – will be, making it easier to flock. Professional equipment is round about 45 000 volts. My device is set at about 30 000 volts.
    Some of my endresults:
  2. McLarenboy
    McLarenboy Member
    Belgium
    So with that out of the way, here’s what you’ll need:
    - Flyback transformer from a CRT-monitor (the bigger the better)
    - Plastic container with a lid
    - Metal sieve
    - Silicone glue
    - Some electrical wire
    - Pvc-pipes
    - Flockfibres, I get them at Home PIN Floc
    - Glue, I use a single part glue (test with two part epoxy have all failed)
    Step 1 – flyback transformer
    Before removing this transformer from a monitor it needs to be properly discharged in order not to get a nasty shot of electricity. For this please check video:
    Step 2 – converting the flyback to be powered by a socket
    On the back of the flyback you’ve got lot’s and lot’s of pins. In order to power this by a socket you’ll need to find the + and – pin on the flyback. I know nothing about electricity so I went to my local electronics shop, also a tv-repair shop will also be able to help you with this. Basically they gave me the following schematic (and did the work for me) and that’s what it takes to convert it. So print it out and take it to either one of those shops and they’ll understand it.
    After that you’ll need to attach some electrical wire on the + and – pin to have the length to connect the positive wire to your container of fibres and the negative wire to the part which you need to ground.
    Step 3 – flocking device
    Drill a hole in your plastic container and connect some pvc-pipes to it in order to have a grip or handle. The lid of your container needs to be cut up so you can glue the flat sheet of your sieve to it. Make sure you have a metal sieve which is large enough to cover the lid of your container.
    Cut your metal sieve up so you end up with the flat sheet which you can then glue onto your lid.
    Put the positive wire through the pvc pipe and through the hole of the container to be connected to the metal sieve. Make sure you have enough length in order to put the lid next to the container in order to fill the container with fibres.
    And now you’ve got a flocking device.
    In this video you can see the process to actually flock a part:
  3. milez
    milez Active Member
    wellingborough, northants
    Is there any way to tell why size flyback there is in a monitor?
    Thanks for the guide mate.
  4. karglass
    karglass Member
    omagh
    looks pretty dam good ,well done
  5. milez
    milez Active Member
    Could you post some pics off all your setup aswell please mate.
  6. McLarenboy
    McLarenboy Member
    Belgium
    I'd rather not because you can't get any more then DIY then mine ;) In regards to the flyback, the bigger the better. I took mine from a 19inch pc monitor
  7. garyd
    garyd Member
    Lincoln
    Awesome guide! Not something im going to attempt, But still awesome. Well done mate.
    Gaz
  8. s50b30
    s50b30 Member
    looks great!
    can¨t you use some parts in the crt monitor to power it from a socket?
  9. McLarenboy
    McLarenboy Member
    Belgium
    probably, but i don't have the knowlegde to know what parts you need for this.
  10. Emperor
    Emperor Member
    germany
    LOL video is blocked in germany.........another step forwards freedome i guess^^
  11. Dori-points
    Dori-points Member
    Midlands
    What glue is it chap? Fancy a go at this myself
  12. Sam H
    Sam H Troll Dispatch
    teamd3.co.uk
    Capacitors on a CRT monitor can kill. Be careful.
  13. the stig
    the stig Active Member
    SE london
    you cant beat a propper bit of kit,with the CORRECT 4part epoxy glue!!
    your flock supplier i would say needs changing if he wont sell you small quanties of flock!!!
    fair play for you efforts tho,and as lighteneing says becarefull,your life aint worth saving couple quid!
  14. mcxxvi
    mcxxvi i take pictures
    Shanghai, China
    what are the benefits of flocking? other than looking pretty obviously
  15. richy d
    richy d Active Member
    birmingham
    If you want to do this with the proper glues it will cost you about £80 for the proper 4 part epoxy adhesive,then about £20 per kilo of flock,plus the parts to bodge up an applicator.
    Then theres the hassle of finding someone to supply you in small quantities,trust me a lot of suppliers can't be arsed with a bit here and there.
    Save your self some serious hassle and get it done properly.....by me!:nod:
  16. richy d
    birmingham
    Reduces glare from the dash:thumbs:
  17. McLarenboy
    McLarenboy Member
    Belgium
    it's tubvinyl one component glue
  18. richy d
    birmingham
    So how are you masking imperfections with no pigment in the glue??
  19. Stavros
    Stavros Active Member
    Isle of bollocks
    Yeah man, im blinded aaaaalllll the time from dashboard glare. Oh, hang on, it's never happened in my entire life.
  20. supernova-dw
    supernova-dw Active Member
    Vientiane, Lao.
    Good guide!
    @ Richy D, what kind of prices do you charge?
