HSD Coilover problems. Wrong size holes.
Thread in 'Technical Questions' started by Crossy, Apr 24, 2016.
Tags:
  1. Crossy
    Crossy Member
    Kildare, Ireland
    Hi,
    Has anyone ever had this problem with HSD coilvers for an s14?
    The bolt holes on my new HSD's appear to be too small. The bolts which go through the hubs wont go through the Coilovers. The holes in the Coilovers are too small.
    Do I have to drill the mounting points or have I been supplied a set with the wrong hole size?
    Photos below.
    Thanks
  2. ali///art
    ali///art Member
    Are they S13 coil overs by any chance? They have a smaller hole than the 14mm bolts on S14/S15. Double check you ordered S14 coil overs not S13 ones. Unless you are fitting to an S13, then just drill the holes. Or you've been sent the wrong ones.
  3. Crossy
    Crossy Member
    Kildare, Ireland
    Thats what I thought originally also but I purchased a full set for an s14 and the rears fitted perfectly. It just seems to be the fronts. Maybe they mixed the sets up or something.
  4. PhilMorrison
    PhilMorrison WholeLifeCrisis
    Staff Member
    Birmingham.
    Hi, the fronts appear to have S13 bottom brackets for some reason. Give the guys in the office a ring and we'll get it sorted immediately. Apologies about this.
    Tel: 0845 869 2555
