https://www.driftworks.com/forum/th...rbo-rare-60mm-billet-compressor-wheel.281623/ I send via UPS, typically next day. Also have a new HX40 Super, 60/86mm billet comp wheel with the rare 10 blade 76/64mm turbine wheel, 17cm2 T4 flange if this suits better
I've got a new HX35 with 12cm housing. I've cut down the turbine to remove a load of excess weight including the internal wastegate, and was going to have a 3" vband welded on and the wastegate hole welded up. Or I have a Turbonetics T4 turbo, 7668 hurricane vanessa, as new only been on an engine for startup. Oil lines included, and 3.5" vband to 4" downpipe
