Hydraulic Handbrake Law/Legality
Thread in 'Drifting Chat / Pictures / Videos' started by Rubix_Cube, Jan 13, 2011.
  1. Rubix_Cube
    Rubix_Cube Member
    Hey folks,
    Considering buying a hydro set up. Just heard mixed verdicts on the legality of it.
    Can anyone clarify this?
  2. lozza
    lozza ChickFoot FTW!
    It's legal as long as you still have a parking brake for MOT's etc. So just keep your standard one as well :)
  3. Rubix_Cube
    Rubix_Cube Member
    How does it plum in to allow both. Just curious to know.
  4. kam
    kam I've touched Chris Parry
    Its a completely different system.
    Presuming you're talking about the s13 in your sig, you'd have a cable handbrake and a hydraulic handbrake.
  5. J_K_P
    J_K_P Active Member
    MOT needs a cable or mechanically operated brake that stays on by itself that is seperate from the hydraulic braking system of the car.
  6. Yeah_Mick
    Yeah_Mick Beauty Purr!
    my car passed an mot fine with the hydro, got pulled numerous times and when asked what it was i explained, i even had to show one policeman that it was actually a hand brake and not a lever for NOS :wack:
    but if its for the 13 in your sig, then dont bother with a hydro as it wont be an improvment i dont think.
  7. fesoj
    fesoj Active Member
    its legal, aslong as you can leave it on when parked...
    just plumb it in alongside your existing cable brake....
    but as Mick says...no point in an s13
  8. kam
    Its not.
    You need a mechanical handbrake system separate from the cars main hydraulic system.
  9. TheChin
    TheChin Member
    Its great when people give wrong advice.... :wack:
    • Informative Informative x 1
  10. tooley
    tooley ドリフトキング
    its a world car requirement that all handbrakes mechanical or electronic (most modern top end cars have electronic handbrakes, calpier with solinoid to wind/rewind) to be seperate to the hydraulic breaking system. Aditionaly if electronic should have a manual release.
    so kam is right, as long as you keep the stock cable one in your all good.
    #10 tooley, Jan 13, 2011
  11. Yeah_Mick
    forgot to mention, that i did still have mt standard handbrake aswell, but as for actually having a hyro fitted its perfectly fine
  12. CrabsterDrift
    CrabsterDrift Callum Craddy
    yep you need the original still installed and in working order. My mate took his out as his hydro has the ability to stay locked on and be used as a parking brake but his car failed. Once the standard one was back in alongside hydro it passed straight away (bmw m3 '98)
  13. fesoj
    fesoj Active Member
    Tis isnt it!
    Mine passed...no idea why then!
    Must have been a slack station i guess!
  14. -sideslide-
    -sideslide- "ent it"
  15. Jme
    Jme Member
    f*ck me if that dont lock the rear wheels up nothing will!
    A working s13 hand brake is amazingly good anyway
  16. Rubix_Cube
    Rubix_Cube Member
    My stock handbrake is very good. I have an R32 GTR setup, i think, inboard drums and then rear callipers.
    I might leave it as it is just now then and see how it goes.
  17. CIH
    CIH Member
    I think it can stretch the cable if it's given beans too often. Not really a problem for S13/14 but avaliability is a prob for my S12 (as an example).
  18. muddyell
    muddyell Member
    Id just leave it as it is. As far as ive seen the stock handbrake is very good in them anyway and ive been in a few without hydros
  19. FireStorm999
    FireStorm999 Active Member
    unless uve got a very friendly MOT guy your hydro alone will not pass.
    as said abive you need a mechanical handbrake.
  20. David Wilson
    David Wilson Member
    It is also worth mentioning that even if you can lock your hydro brake, the pressure in the fluid can fall over time (overnight) and then you will be finding your car at the bottom of a hill. Even if your car isn't road legal, keep the cable there just for parking.
