Hyrdo not locking but working
Thread in 'Technical Questions' started by Widowbee3.8, Nov 3, 2022.
  1. Widowbee3.8
    Widowbee3.8 New Member
    Hi I’m just looking for some help I installed my chase bay hydro onto dual caliper (brembos 4 piston) a few days ago and it has pressure on the Handle and locks when the tires are in the air but once I’m in motion driving around it doesn’t I tried to initiate a drift it doesn’t lock it keeps on spinning slowing the car down(yes I’m putting the clutch down when pulling it) any tips on how to make it work? Checked all lines to made sure (they are tight and no leak) also went through a bottle of dot 4 fluid bleeding them and still no change .
  2. smokebillowing
    smokebillowing Active Member
    How did you bleed it?
  3. oscar
    oscar Member
    The master cylinder is too big.
    Simple as.
  4. Beefy
    Beefy New Member
    What happens if you apply slight brake pressure to the main pedal?
    Assume you've plumbed it in-line, not a dual-caliper setup?
  5. Widowbee3.8
    Had a friend pulling on the hydro 3 times and hold it down. Then i open inner brembo bleeder screw and repeat the process for the outside bleeder screw as he holds it down.
  6. Widowbee3.8
    It just breaks normally I’m running a dual caliper setup with double brembos on the back
  7. Beefy
    Beefy New Member
    Try bleeding with the caliper bleed valve higher than the cylinder. Air can travel to the "Highest" point of the system and stay there. Failing that, check seals aren't worn on hydro cylinder.
