Info on Rear Geomaster Hubs & the benefits.
Thread in 'Drifting Chat / Pictures / Videos' started by CJRdrift, Nov 9, 2013.
  1. CJRdrift
    CJRdrift Member
    I just wondered who knows the benefits for the rear Geomaster hubs, am I right they will lower your setup lining all your geometry bars to a stock position and increase grip?
    I think its the only thing that I dont have on my car now and wondered if its needed or not.
  2. Chimp
    Chimp Member
    fuck yeah... best thing i have fitted on my car bar non. the grip they give is mental... well worth it...
  3. Clive
    Clive Active Member
    I use them.
    Unless you have mega powers just run bigger tyres IMO
  4. DtheBUK
    DtheBUK Active Member
    They also shorten the distance between roll centre and centre of gravity which gives you more roll stiffness without affecting bump stiffness
  5. CJRdrift
    CJRdrift Member
    cheers guys, i think I understand from all the comments, nice one, i just wondered if it was worth getting them.
    #5 CJRdrift, Nov 11, 2013
  6. FireStorm999
    FireStorm999 Active Member
    Why? Surely geos help massively with bump steer and if ur cars real low it helps with cornering grip too?
  7. Clive
    Clive Active Member
    Can't go really low without headache.
    Bump steer, yes the fronts are sure worth it full stop... But the rears are a pain, but well worth it if you have big powers.
  8. 200sx_
    200sx_ PS13 x TD Power
    What Clive said basically, know quite a few people having problems with the rears when running lowwwww but the front look good to use. I was thinking about just getting the fronts, ended up with Clarkey hubs instead
  9. ZacKisBacK
    ZacKisBacK Member
    Even with the Driftworks CS2 coilovers?
  10. 200sx_
    Not to do with the coil overs (If were talking about the same problem?) its to do with driveshafts
  11. ZacKisBacK
    ZacKisBacK Member
    Ok, thank you for your reply, I thought it was related to the coilovers length. Could you give me some more details about this driveshafts problem? I am looking for a solution for my front and rear knuckles and don't want to be stuck regarding the ride height.
  12. Clive
    Clive Active Member
    Yes, with cs2.. Which I'll add are amazing and worth every penny no matter what the car!
  13. ZacKisBacK
    ZacKisBacK Member
    I already have the CS2 with swift springs, but I'm wondering if the rear knuckles would go there and seeing your reviews regarding this ride-height issue, I would like to know more for sure if you don't mind!
  14. CJRdrift
    CJRdrift Member
    hmm i dont have the rears yet and have smashed 5 rear shafts, not the same side though its the cups that break too.
  15. stefan
    stefan Member
    how do you find the swift springs compared to the stock springs and what rates are you running?
  16. ZacKisBacK
    ZacKisBacK Member
    Hi Stefan, I only drove the car once since the LS is in, it's been nearly one year that we are working on it now, so I can't really tell you the difference. I bought the CS2 and swapped the springs for 11kg fronts and 9kg rears after discussing the subject with Kam and other people that swapped an LS engine in a S-chassis before. I also have a pair of 7kg swift springs if I feel the need to go back to the original CS2 spring rates set-up once I'll get some time behind the wheel. I plan on doing a full test with both swift set-up (11/9 and 9/7) opposed to the CS2 springs (9/7) once the car is finished btw, I'll let you know!
  17. Chimp
    Chimp Member
    i make shaft spacers which a fair few guys run to stop this happening...
  18. Adam-MGTF
    Adam-MGTF Member
    I was going to buy some a while back but the listing recomends 18" wheels and I HATE big wheels. I emailed dw asking why 18s were needed and never got a reply (so didnt spend my money) can anyone give any info on this?
  19. Clive
    Clive Active Member
    I run 17" all round.
    Have even got GTR r32 wheels on the rear ok with 25mm spacers.
    Need 18"s if you have aftermarket lca's... Can grind them a bit ...
    So DW state 18's to cover their arse on all types of possibly :)
  20. kam
    kam I've touched Chris Parry
    PM me your email address and I'll look into why you didn't get a reply :)
