Is is possible to install 2 dry sump oil systems on V8's?
Thread in 'Technical Questions' started by oversteer, Nov 5, 2012.
Tags:
Thread Status:
Not open for further replies.
  1. oversteer
    oversteer New Member
    If yes, how will that setup work? Also what are the main advantages and disadvantages?
    Thanks in advance
  2. Cheshire190e
    Cheshire190e Active Member
    V8's usually have 2 heads. Not 2 blocks
  3. be11
    be11 camber king
    Why would u want 2?
  4. oversteer
    No buddy, just wondering if V8's could become oil thirsty when they are side ways
  5. Stavros
    Stavros Active Member
    Any engine can, V8 or not, but why two dry sump systems? Don't matter if it's 1 or 100000, if it does the job it does the job.
  6. Trickysadd
    Trickysadd Member
    Ive fitted a couple of systems on of all things V8 mgb race cars , with single systems on large bore Rover V8's.
    Never even come across a twin system.....why ?
    There are a good few companies that supply the systems and will design one to your need if you can't. Why not call one ?
  7. Rossc0
    Rossc0 Diesel Skidder
    Dafuq is going on in here? I see no advantage to it working, even if you wanted one, and even if it did make any sense at all
  8. -sideslide-
    -sideslide- "ent it"
    I dont see how a twin system would work or at least that well. I think you will be fine with one dry some op.
  9. akinadan79
    akinadan79 Active Member
    Could you explain a bit more on your thinking behind this mate, and maybe somebody could give you a more detailed technical response as to why it would/wouldn't be needed. I can't find anyone anywhere who's running a twin dry sump setup in Motorsport though, so I suspect it isn't necessary.
    Maybe an increase in dry sump system capacity would suffice (if even required) rather than going down the twin setup route?
  10. Bronzer
    Bronzer Member
    What do you mean by twin system? Two pumps? Most dry sump pumps are modular? If you want more oil pick up points i the sump you just change the sump pan and add another gear unit on the oil pump, but it still runs off the same pulley.
  11. oversteer
    I should have thought more about my question since its quite ridiculous! I apologize and thank you at the same time.
Thread Status:
