Is This Diff FUCKED or can I still Weld It?
Thread in 'Drifting Chat / Pictures / Videos' started by GB / John, Feb 12, 2011.
  1. GB / John
    GB / John NDC Runner Up 2012
    Washington / Newcastle UK
    I was hoping to fit this 325 Diff, to my 328, after opening it up its pretty fucked.
    The bits that fell out:-
    The 2 small cogs are completely fucked, but can I still put in a plate and weld it?
  2. FreddieS
    FreddieS Active Member
    Godalming or Salisbury
    aslong as the crown and pinion are fine, you can weld it up ;)
  3. GB / John
    Yep they appear to be fine, turn ok without any stiffness.
    The larger cog can be put back in, it came out when I took a output shaft out.
  4. FreddieS
    Yeah, you'll want that in there, as thats what trasmits power to the output shaft (see the splines)
    weld all that shit together, with the planetary gears in there, nice and easy ;)
  5. robrs2
    robrs2 Active Member
    Teesside
    Just weld the side output planet gears to the diff centre. If you have TIG it's far better
  6. GB / John
    Got the other gear back in now, so just weld in a plate between the 2 gears as I would do normally?
    It all seems to move freely, few marks around but none on the gears.
  7. milez
    milez Active Member
    wellingborough, northants
    Yeah just weld it all up. Will be fine :)
  8. rtlkyuubi
    rtlkyuubi Member
    Sheffield
    this happended on my viva:
    so just weld like so:
  9. sx slider
    sx slider Member
    dude weld it, if it breaks weld it again. and then if you break it weld it like it was a battleship.
  10. GB / John
    lol cool, it will be getting welded then. I'll keep the 328 welded diff as a spare.
  11. sammysideways
    sammysideways Active Member
    ETWE S P Brown 3S Mess HMS York BFPO 430
    i have a small case diff already welded for sale if thats any use?
  12. GB / John
    Small case is no good unless it comes with prop and driveshafts for pennies?
  13. sammysideways
    nah but you can pick those parts up cheap
  14. GB / John
    Diff now welded, seems ok, turns freely by hand.
  15. n1tr0_9
    n1tr0_9 Member
    Cranbrook, Kent
    Proper job!
  16. Sw3eDz
    Sw3eDz New Member
    surrey
    nice job mate, looks like mine lol.
  17. conor1
    conor1 Member
    dublin
    so thats how you weld a diff and now i know my cusco aint a welded diff cheers dudes
  18. Sparco_Tom
    Sparco_Tom Member
    Aylesbury, Bucks
    :) lovely job take alot to break that
