JPR 200SX
Thread in 'Project Cars and Builds Threads' started by Vlad_SX, Jun 23, 2018.
  1. Vlad_SX
    Vlad_SX Member
    Brasov/Bucharest, RO
    Hy guys....don't even know where to start....so i've this car in 2010 as a total wreck, without a motor...and since then, made it, broke it, made it again, broked it again...u know, the usual :)). Since i'm running one of the top race engine and mapping companies in Romania....i've done almoast nothing to the car's look....digging down into the mechanical part...Till now i had about 5 SR's on the car, every one made with different specs. I took the car apart last week, to get it all nice and s**t... download. download (3). download (4).
  2. Vlad_SX
    Vlad_SX Member
    The first motor was this SR...wich belw a rod at the first drift event i went to, 2012 i think.
    Spec: Oem bottom end
    GTI-R oil pump
    GTI-r Cams, no VTC
    RC1000cc injectors
    Megasquirt 3 ecu
    Ultra China GT35 @1.4bar
    12036911_1653504471556651_6914186567265580239_n. 12029651_1653504664889965_2829460607366092849_o. 12015228_1653504578223307_8320489806918949365_o.
    11990694_1653504504889981_2553974170815299680_n.
  3. Vlad_SX
    Vlad_SX Member
    Next one was a pretty stock S14 engine, gust ARP's and Cosworth head gasket, S15bb turbo, jecs 540's and a Haltech ecu, also got the suspension and the lsd. This motor is still running on a friend's car, had to sell it due to a very good offer.
    35924611_1034443250036011_6696561949628432384_n.
  4. Vlad_SX
    Vlad_SX Member
    Next one:)). A weard conversion, of a roller rocker sr20de, made turbo, s14 pistons and rods, oil squirter holes drilled, tomei poncams, subaru vf35 turbo, motec m84 ecu, 540 injectors, running about 1.8bar of boost. I've started grip racing with this one. 35922353_1034443240036012_3214504939103453184_n.
    35900528_1034455283368141_8718423267418832896_n.
  5. Vlad_SX
    Vlad_SX Member
    And here we are to this day. 2 days ago just finished my new setup. I will race the car in the time attack championship.
    SR20DE 02 block
    S15 Head (ported)
    Supertech head internals
    Tomei Poncams
    OEM GTI-R Pistons
    ZRP Rods
    GTI-R 19mm rod bearingsGTI-R Oil pump
    Greddy oil pan
    Greddy TD06h-25G 8cm (also have a T67 25G 10cm for other type of tracks)
    Motec M84 Ecu plus the JPR Electronic Throttle Controller (made by me)
    AP Racing dual plate clutch with a custom alloy fliywheel
    Also will build a full mil-spec Ecu harness
    Also have some new AP, 365mm, water cooled brakes to fit, Proflex evo 2 dampers. Aaaaand i have to get my balls up and start working on the bodywork.....:|
    35671596_1031771283636541_1889329149705715712_n. 35728656_1031771653636504_1589938623157895168_n. 36002540_1034468303366839_6322480052017561600_n. 36002479_1034443223369347_4320550208569081856_n. 35923585_1034441276702875_3297399921040162816_n.
  6. PRT73
    PRT73 Member
    Great , you have movie ?
