Is there any other rear diff that fit a jzx100 ie altezza,hilux,haice any help would be great cheers brian Im looking at different ratios
The crown wheel and pinion from a ma70 supra is 4.3 and they fit in the casing .. I think it's the 3L n/a model that the 4.3 is in
Your better to check your axle code on the vin plate before you go buying shit. Supra and altezza diffs are different sizes (Altezza it a 7.5" / supra 8" ) its the second to last 4 digits and starts with an F. For example mines F303, as its a 7.5" ring size, A 8" ring first digit is G. Heres a link to desipher the code. Celica-GTS.com - Differential Codes And if you go by the KAAZ diff codes the altezza and chasers are totally different. KAAZ USA | Limited Slip Differential-Toyota So if i'm not mistaken you've got an 8" diff chap
hmmm, looks to me more like B01B which would be a 145mm crown with a 3.30 r&p But, the last number doesnt stack up against the chart so, going by the kaaz chart your car would be a sat/dat 3035 diff which is the same as mk3 supra's and 81's/91's ect IE, An 8" diff. I'm just wondering if your model has the torque sensing diff due to the weird axle code? Tbh, i'm quite confused by yours,but this links usually pretty good for decoding it all. Decoding Your Toyota VIN - Toyota Nation Forum : Toyota Car and Truck Forums
lol its a pain in the ass ill pull it out on monday morn and see whats inside as it had a lsd fitted to it i think it was from a mk3 turbo supra just want a 4.3 for it
this what i found dont seem right though B01A 3.42 2 pinion open 7.5" ring gear B01B 3.42 4 pinion open 8" ring gear B01C 3.42 2 pinion posi (OEM limited slip)
Hello Friends, I have is200 Automatic Transmission, with 3sge engine, but need to Swap to 1jzgte, I have other Gx110 MarkII 1jzge with the Diff B01C and the diff for is200 is A01B, I real need your help and advise if the diff of mark2 can feet on my Altezza
Hi lads new to the forum. I have a jzx100 mkII 99. And my diff is knackered I don't really know to much about them but I have it out of the car now and as far as I can tell all bearings are crunchy and gears look worn. What is my diff and what alternatives are there? Will the altezza fit in my casing? {} {} {}
Well man new to this now myself and was wondering if you figured out your question? I know its a couple years ago now but just chanceing it
