currently gathering bits to complete an s54 gearbox swap on my jzx100 chaser, so far I have Clutch Pmc gearbox adapter and flywheel E46 m3 getrag gearbox Is200 pedals and clutch master cylinder Like the rb swaps in an sbody the propshaft will need to be customised, the bmw gearbox use 3 bolt applications and all bmw box look the same on gearbox shaft end. Just wanting to know is there any other propshaft that shares the same prop end as the m3 box that I can use as I will be mainly using my jzx propshaft and just need the gearbox side chopped and machine balanced on.
