Jzx100 mark ii dmax 1jz vvti factory manual
Thread in 'Drift cars for sale' started by minicrazy123, Aug 18, 2018.
  1. minicrazy123
    minicrazy123 Member
    1JZ VVTI single turbo
    161,500km
    Factory manual R154 gearbox
    ACT Extreme 6 PUK clutch / Pilot bearing and realease bearing
    Greddy front mount intercooler / pipe work
    Greddy Oil Cooler / lines & sandwhich plate
    Greddy E01 Electronic Boost Controller with electronic screen and hand commander for Greddy E Management use... Running 0.9 bar of boost running roughly 330BHP
    Blitz electronic turbo timer / Battery voltage metre
    Tomei uprated turbo elbow / J pipe delete
    Custom bigger aluminium power steering reservoir with overflow catch tank (C.T Fabrications)
    Custom aluminium battery tray
    Black silicone top / bottom radiator hoses
    HKS mushroom air filter
    Full 3" turbo back exhaust system / Custom decat / Rear silencer removed and strait piped
    ABS / Traction Control disabled
    Auto Gauge Oil Pressure / Oil Temp / Water Temp / Boost Gauges in dashboard passenger side
    Mot till 11/9/18
    Suspension Chasis :
    HSD Monopro coilovers
    Ikeya Formula front upper camber arms / Modified for more camber
    KFD Minty Fresh rear adjustable arms / 3 sets
    Manual Differential welded locked
    Cusco rear strut brace
    Unknown carbon fibre front strut brace
    Front underneath subframe to chasis brace
    Hardrace solid rear subframe bushes / Mounts (brand new)
    Brand new handbrake shoes
    Brand new LS400 front big brake conversion
    Custom of set brake caliper adapters
    Garage-D 20mm front RCA's (roll centre adjusters)
    Lexus IS200 inner tie rods & outer track rod ends
    Heyman 800ps modified hub knuckles for big lock
    Full wheel alignment recently done (Hunter)
    Underneath fully undersealed / Extremely clean / No rust
    Interior :
    20th Anniversary Edition interior / Door cards and rear bench (different pattern to Chaser)
    Bride Zeta II drivers seat (handed)
    Bride Zeta II passenger seat
    (Re trimmed like brand new)
    C.T Fabrication custom solid mounted seat rails
    1kg fire extinguisher (mounted to drivers seat rail)
    Factory Japanese double din head unit with sat nav
    Fully working ice cold A/C (just been re charged)
    Original factory green floor mats
    Chrome metal gear knob
    After market steering wheel painted same colour as the car... with genuine Nardi centre horn button / After market steering wheel boss
    Exterior :
    Paint Work metallic brown (painted in Japan) door shuts etc... Originally pearl white /colour change has been declared
    Full genuine D-Max body kit
    Ganador outer wing mirrors
    Original Toyota front wing corner lights
    Original Toyota wind deflectors
    Gen 2 rear boot and rear lights
    Work Emotions alloy wheels
    Fronts : 18" 9.5J ET23
    Rears : 18" 9.5J ET23
    Front tyres tri-ace 225/40 18- fitted on the 13/8/18
    Mid range rear tyres 225/40 18 - fitted 8/7/18
    15mm front hubcentric wheel spacers
    Spares :
    N/S/R door card
    O/S/R outer light unit
    Brand new still in packaging Toyota front clear indicators for bumper!
    O/S/F gen 2 indicator lens
    O/S/F clear side indicator lens
    O/S/F Head light
    Standard front camber arms
    Standard rear arms
    Standard subframe front mounts
    Standard inner tie rods and outer track rods
    Standard lower swivels / knuckles
    Standard turbo elbow
    Standard front brakes (complete)
    Boot / Fuel flap levers and cables
    Genuine Nardi steering wheel (came with car originally)
    Bad bits :
    Front bumper has seen some wars, been fiberglassed back together on both corners, solid just needs some filler and sanding down, havnt got a recent pic of the bumper but will get one ASAP.
    Side skirts have few minor marks
    Rear bumper has small crack and stress cracks (not bad)
    Trim on bottom of drivers door is white
    N/S/F wing has small crack in the paint above wheel
    I'm not 100% sure I want to do this yet, just seeing what interest ect I get.
    swap for a good spec ps13/s13/s14 or similar, not really interested in a cash sale.
    IMG-20180513-WA0048.
    IMG-20180513-WA0049.
    IMG-20180513-WA0046.
    IMG-20180513-WA0043.
    IMG-20180513-WA0036.
    IMG-20180513-WA0034.
    IMG-20180513-WA0018.
    IMG-20180513-WA0009.
    IMG-20180513-WA0024.
    #1 minicrazy123, Aug 18, 2018
  2. Jordan Bunting
    Jordan Bunting New Member
    Northamptonshire
    Would you be interested in a nissan pulsar gtir?
  3. minicrazy123
    minicrazy123 Member
    No sorry bud
  4. Reece hazell
    Reece hazell New Member
    Kent
  5. rickyysojr
    rickyysojr New Member
    Germany
    What year is your car?
  6. Jordan Bunting
    Northamptonshire
    Could you send me some photos of the bad points mate please ?
  7. Mate383
    Mate383 New Member
    hey,
    are you interested in a R33 GTST?
  8. Mr III
    Mr III Active Member
    Herts
    Is this still available?
  9. Ashley james
    Ashley james New Member
    Cornwall
    Is this available? Do you have a contact number please?
  10. KillboSlaggins
    KillboSlaggins Active Member
    Hampshire
    Still got this or you decided to keep it?
  11. minicrazy123
    minicrazy123 Member
    Decided to keep it mate, thanks for the interest though!
  12. KillboSlaggins
    Hampshire
    good decision dude!
