For Sale Jzx100 Mark ii great little project
Thread in 'Drift cars for sale' started by Original-_, Aug 3, 2023.
  1. Original-_
    Original-_ New Member
    Toyota JZX100 Mark ii Tourer V
    £12,500 Ono
    Car is for sale due to it needing work that I really don’t have the time todo
    1998 build date
    AUTOMATIC
    1JZ-gte
    190k km/ 118k miles
    New timing belt + all seals and gaskets replaced at 180k km
    Clifford alarm and immobiliser
    LSD
    MOT Up at the end of the month
    Spec list
    Series 2 Tail lights/Grill/Running lights
    New BC coilovers fitted less than 500 miles ago
    SSR Vienna Courage on the front 8J+38
    Weds Cerberus 2 on the rear 9.5j+38
    Hardrace rear arms
    Cusco sway bars F&R
    Poly bushed castor arms
    Power flex steering rack bushes
    Hardrace diff bushes
    Cusco front upper arms with
    Megane rs front calliper conversion with new pads disks and hanbrake pads all around
    Braided lines through out
    Garage-D LCA Spacers
    Wasp alternator
    Hybrid factory turbo
    Hpi J-pipe delete
    Hpi intercooler
    Hpi turbo back with full custom 3inch exhaust
    Hks Boost controller
    Unknown body kit on it
    Nardi 330mm steering wheel and boss
    Bad points
    • Cars paint work could do with some work and the kit isn’t paint matched very well
    • Carbon interior pieces have seen better days
    • The wheels would benefit from a referb and one of the front wheels has a little off balance which can cause some vibrations through the steering wheel at certain speeds
    • Coolant header tank is starting to crack and the radiator is starting to show sings of yellowing.
    • Light surface rust in the boot gutters
    • Headlights are starting to yellow
    • Chrome plating is starting to ware and chip off
    • Left front wing has a little bit of damage from the wheel catching it
    • Turbo will need replacing asap but the car drives but I don’t want to push it
    I would recommend trailering the car as I can’t promise the turbo will last your journey the car hasn’t been driven for a while for this reason
    Can provide any pictures of the problem areas on request.
    INSTA-7010.
    IMG_4087.
    IMG_3039.
  2. Original-_
    INSTA-7021. IMG_4085.
    64327862-3C5B-4DA7-84FC-816596191763.
    IMG_3226.
    INSTA-7013.
  3. Original-_
    Please feel free to check out my Instagram for more photos of the car @v.52jzx
  4. Original-_
