Right thought I would do a new advert to avoid ay confusion on this one. Full running car and made 365bhp @ wheels at only 1 bar (Circa 430bhp @ fly) !!! The coil packs are tired now so its mapped safe to 1 bar, Audi TT coil pack upgrade will see it comfortably back over 500bhp @1.5 bar (power it made before on old engine) OR fit stock ones.. up to you... For now though the power is more than enough to have some fun - see vids Mapped by Marin at mb properly and seriously goes well now!!! Full build thread can be seen here http://www.driftworks.com/forum/dri...cresta-1jz-im-gonna-famous-drift-project.html The spec is in a word "delicious" haha.. some serious cash has gone into this car... and im not 100% on letting it go as i love it but my R34 is nearly ready and I don't want to be greedy and have two awesome 4 doors... whats on offer is simple so PLEASE READ carefully.. Price: £10000 ONO PX - YES IF BUT BARE IN MIND I WONT PAY £10k FOR AN S-BODY FREE - Cresta complete car so all the lights, panels etc there - only thing missing is engine/box Delivery available for a small fee - just ask Engine: 365bhp@wheels.. at only 1 bar 1JZ-GTE Non VVTi Holset HX35 Single Turbo / 12cm Ex Housing Turbosmart Comp 40mm External Wastegate (routed back to downpipe) 6Boost Ceramic Coated Twin Scroll Top Mount Manifold Solid Fabrications Custom 3' Downpipe Solid Fabrications Custom 3" Straight Through Exhaust System (straight piped rear - now on v band rear section) HKS FCon Gold V Pro Type A HKS 650cc Injectors Walbro 400LPH Internal Fuel Pump Sytec FSE Fuel Pressure Regulator HKS Cams 256 IN, 256 EX HKS Fine Tune Timing Belt HKS Metal Suction Pipe HKS Air Filter Greddy Oil Cooler With Relocated Oil Filter / Braided Lines Greddy Top Rad Pipe Blitz Intercooler Kit / Shortened Pipework / T Bolt Clamps Blitz Rad Cap Custom Tripple Brass Core Radiator Sard Engine Torque Damper Millers 10w60 Engine Oil Millers Gearbox Oil / Diff Oil Air Conditioning Delete (Conti 6PK1888 Shorter Belt) Custom P/S Pump Support Bracket Hydraulic Fan Delete Pace Oversized Electric 16" Fan 2JZ Waterpump. CDF Racing 2JZ Lightweight Waterpump Pulley CDF Racing 2JZ Lightweight Alternator Pulley CDF Racing 2JZ Lightweight Power Steering Pulley Nozzs 1JZ Clear Timing Belt Cover Weld Racing Gold Engine Cover Chassis / Drivetrain: R154 Manual Conversion with Remote Shifter Custom Aluminium Solid Cradle Bushes Northshore Toyota NZ TRD Quick Shift Kit Weld Heavy Duty Brass Shift Linkage Collar Weld Heavy Duty Clutch Pedal Pivot ORC Twin Plate Metal Clutch / Lightweight Flywheel Comp Brake Hydro Handbrake with Wilwood Master Cylinder & Hel Braided Brake Lines Aftermarket Front Pads / New OEM Rear Pads HSD Coilovers 15F/8R Cusco 2 Way LSD Nickson Motorsport FIA Weld In 6 Point Roll Cage with Double Door Bars, Roof Diagonal, Rear X & Harness Bar Cusco Front and Rear Strut Braces Ultra Racing Front Antiroll Bar with Poly Bushes & New OEM Links Cusco Rear Adjustable Antiroll Bar with Poly Bushes & New OEM Links Ultra Racing 8 Point Front Lower Arm Bar Ultra Racing Chassis Bars Cusco Solid Subframe Bushes Ikeya Formula Rose Jointed Front Upper Arms / Camber Arms Ninja Power Steering Rack Spacers Hey Man 800HP Forged Steering Knuckles Uras Strengthened Tie Rods Super Now Rose Jointed Tie Rod Ends IS200 Tension Rods with Super Pro Offset Polyurethane Bushes Super Pro Lower Arm Polyurethane Bushes Completely Rebuilt Front Suspension Assembly Inc Hubs (New Bolts / Bearings / Uprated Bushes / Cleaned / Painted) Exterior: Vertex T&E Front Aero Lip Vertex T&E Side Steps Chaser Rear Bumper D-Max Front Vented Over Fenders Lightened Bonnet / Bonnet Louvres Ganador Door Mirrors Clear Front Corner Winkers Bi-Xenon Super White HID H4 4300K Hi/Lo Super White H3C 4300K Side Bulbs Super White LED 4300K Marker Lights Schroth Tow Hooks Aerocatch Plus Flush Bonnet Catches Lifeline 2.5L MSA Plumbed in Fire Extinguishers Lifeline 2.0L Handheld Fire Extinguisher FIA Battery Cut Off's / Panel Switches Interior: HKS Turbo Timer Defi Link Controller Defi Gauges (Oil Pressure, Oil Temp, Water Temp & Boost) Greddy Profec2 Boost Controller JZX100 Dash Clocks KEY!S Racing Deepdish 330mm Buckskin Steering Wheel KEY!S Racing Buckskin Shift Knob Okuyama Carbing Aluminium Pedals Okuyama Carbing Aluminium Driver Foot Rest Okuyama Carbing Aluminium Driver Floor Plate Okuyama Carbing Aluminium Passenger Plate Recaro Pole Position Driver Bucket Seat / Recaro Side Mount Subframe (7.0KG) Safety Devices FIA Roll Cage / Doorbar / Roof Padding Fully Stripped Interior inc ALL trim, OEM heater matrix, excess wiring, part dash & all sound deadening Interior / Cage all painted in Toyota white Demon Tweeks Lightweight Motorsport Heater with custom ducting Fully Flocked Dashboard Anymore info give me a shout location surrey contact 07442494402 PLEASE NOTE THE BRIDE AND TAKATA DO NOT COE WITH IT - IT WILL HAVE A 4 POT HARNESS AD RECARO BUCKET. FREE # Summary Yes its seen better days at the rear but please bare n mind the money that's gone into this car to make t functional... If I make it all pretty, you will see an add for £13/14k+ Your chance to take both cars and do what you want with the pair... any decent body shop can make the rear nice again...
me too.. dont think people can see past the "rough" look and appreciate the spec and cost thats gone into this thing...!!
Even the spec list doesn't show how much is on this car. Every time I met the last owner it had about 3000 more things added to it. Fucking sounds cool too. Straight up hardcore race car.
yep!! and reason i havnt bother to mot it as a the question was asked on last thread is simply because i expected it would go into europe
You need to change your eBay ad for it to get seen throughout Europe.. It won't show up abroad unless the person searching is on actual eBay .co.uk
because its a comp spec car, whoever buys it would be stupid not to take the spare car for spares tbh.. if "someone" offers me good moey for the donar car I may be tempted
