JZX90 MARK II of DOOOOOOOM.
Thread in 'Project Cars and Builds Threads' started by zombie, Jan 2, 2011.
  1. zombie
    zombie Active Member
    gloucester
    Ok now I thought I should probably make a thread for this to make it easier to keep up with when things do change.
    As many of you will know, I swapped my 1jzR334 for this JZX90, that was owned by Jack after Mitto in Japan.
    The spec is as follows..
    ‎1JZ freshly taken from an auto soarer with 60k on clocks, so never been abused
    new belts, gaskets,
    new engine mounts
    fresh coolant, oil and all fluids etc
    rare factory manual ecu and clocks
    HKS spark plugs
    HKS Fuel pump
    HKS Priest Titanium exhaust
    big front mount intercooler, metal pipework
    Yashio factory rad and rad cap
    twin electric fans
    engine earthing kit
    SARD Silicone piping throuout (new)
    huge engine dampner
    r154 gearbox
    brand new HKS pro twin plate clutch, (£2k worth)
    HKS lightweight flywheel
    braided clutch line
    TRD 2 way LSD
    TRD 4.6:1 Final drive set (new)
    Cusco catch can
    ABS deleted, complete new lines made
    Traction control completly deleted also
    FOOTWORK
    Apexi N1 40 point asjustable coilovers
    TRD 3 arm rear set (new)
    TRD front and rear ARBS
    Yannack rear member locking collars (new)
    Tein steering arms and spacers
    MHC super angle spacers and corretion spacers (new)
    Cusco front strut bar (under bracing)
    Cusco chassic support frames
    WELD diff mounts (new)
    mkiv supra brakes. braided lines
    ELECTRONIC
    GReddy boost gauge
    GReddy water temp gauge
    GReddy oil temp gauge
    GReddy oil pressure gauge
    triple gauge holder jzx90 specific
    turbo timer
    blitz speed limiter defencer
    seriously pimp carrozeria speakers, with matching wood trim from interior
    INTERIOR
    bride bucket seat drivers side
    standard passenger seat
    bride super low drivers subframe
    bride doorcards all round
    full interior and rear bench modified to fit round cage
    fire ext
    snap off hub
    dished naardi wheel
    mitto spec gearknob
    Yannak fly off handbrake button
    Cusco half roll cage
    broadway wide rear view mirror
    blacked out windows, southern style sunstrip
    WHEELS + TYRES
    ROTA grid drift 18x10 et12 all round
    with good federal 595 RSRS
    25mm H+R hubcentric bolt on spacers rear
    AERO & LIGHTING
    Car Modify Wonder SHADOW complete kit (seriously rare kit, the best you can get for a jzx, cost a fortune)
    D-max carbon D1 bonnet (new)
    gandor mirrors
    Unknown aftermarket bonnet grille, meshed
    Origin front wide fenders (new)
    Origin Carbon 3D wing (new)
    240Z wide fender extentions (65mm (rears) + 35mm (fronts)) (new)
    Car Modify Wonder clear winker set (new)
    Car Modify Wonder Clear headlight set (new)
    Koito headlight conversion
    HID lights (new)
    Custom cannards and diffusers (new)
  2. Thomas
    Thomas Needs seattime ASAP
    What the Japanse Mad Max would drive. True story.
  3. zombie
    gloucester
    So I took a trip over to Jacks unit, which coincided with his birthday, went out on the Saturday night and woke up feeling fucking terrible on the sunday ready to make the 3 hour journey back to Gloucester. Tom of team twisted was kind enough to come along to do the job. So we loaded her up, note how HUGE the car is compared to the flatbed, the largest car I think I have seen in the metal!
  4. Romo
    Romo New Member
    Wicklow
    Fuckin ace! looks evil :smokin:
  5. zombie
    gloucester
    Now the car was home with me there was a major issue that needed addressing. The car came over from Japan minus the epic spec Mitto had been running so Jack found a clean 1JZ with R154 and some stock twin turbos to get it running. Everything was great except for some unknown reason it just wasn't making boost. This was about the point I got the car off Jack so I picked it up knowing this.
    After a couple of times out having a look at night time with my good friend Craig, and going through every possibility we could think of and had suggested to us (ECU limp mode, recirc valve fucked, electronics etc) We could feel that the wastegate arm of the front turbo was stuck, most probably closed. So we set about removing the turbo, pretty surprised at what we found!
    The wastegate arm was indeed stuck shut and so probably ran silly boost before shitting itself as above.
    Got in touch with Garage D and got a nice clean turbo on it's way over to me!
    Fitted this and went for a little drive down the road to see if we were now making boost...
    #5 zombie, Jan 2, 2011
  6. razzledrift
    razzledrift Member
    cheltenham
    looks sweet mate sin it on facebook ;) sounds mental!
    cant wait to see it up close
  7. zombie
    gloucester
    #7 zombie, Jan 2, 2011
  8. dirty-diesel
    dirty-diesel Active Member
    looks wicked fella !
  9. milez
    milez Active Member
    wellingborough, northants
    And..............
  10. milez
    milez Active Member
    Bloody hell you replyed already lol
  11. dirty-diesel
    and sounds the nuts !
  12. GethinD
    GethinD [][][][][][][][][][]
    Ellesmere, Shropshire
    Seriously love this car. Looks so evil its unreal!
  13. zombie
    gloucester
    Other than that, have just been sorting out a few little things, took the sunstrip off for some better visibility, insured it, fitted a new battery. The car is booked in for MOT on wednesday and will hopefully be getting registered this week too!
    Just need to bleed the brakes
    refit the front bumper
    sort out a few little things here and there
    oil change
    fit a new HID kit I ordered
    properly fit the indicators
    and it will be good to go and hit up the road!
    Also bought this headunit so I have some music , POW!
    PS incase you were wondering about the spoiler, I have some End plates being made for it as we speak, truly badass!!
    In terms of plans for this year, well drive it, ALOT!
    But Craig has a GT35r that was making 575bhp on his 32GTR lying around. I can't resist so I'm going to slowly stockpile parts for a single turbo conversion and bang it out in a weekend along with a wing exit screamer pipe to be a proper chav.
    Other than that the car will get a proper paint job ASAP, as Jack just did it satin to get the car one complete colour for the time being. Still unsure of colour!
  14. tommahawk
    tommahawk Active Member
    swindon
    Bad ass looking car my mate was telling me about you getting a new ride whilst tattooing me
    His name was Mitch by the way
  15. Chan Dapman
    Chan Dapman Active Member
    Do it a stupid offensive awesome colour. Don't be shit.
  16. zombie
    gloucester
    Mitch Allenden? If so I'm waiting to get some work by him, such a fucking rad artist!
    And A5h my gut is telling me to go purple!
  17. Chan Dapman
    I agree with that. But mental flake or something like that. Or then some luminous yellow decals or something. Would be berserk!
  18. tommahawk
    swindon
    That's the man himself he came to stay at mine for Christmas so got some fresh ink from him
    Next time he is back will give you a shout for a beer be good to meet some more local drifters
  19. zombie
    gloucester
    Or just deep black with a purple flake, in fact that is probably the most likely option!
  20. zombie
    gloucester
    Yeah that's weird he would mention me man! But he trained Steph Birt to pierce who trained me, then I realised he was by far the most impressive apprentice i'd ever seen! So gunna let him finish uni etc and have him do my left leg sleeve!
