JZZ30 Soarer from New Zealand
Thread in 'Project Cars and Builds Threads' started by foto_choppa, Nov 9, 2012.
  1. foto_choppa
    foto_choppa Member
    interior all stripped too
    a visual guide of the camber its running haha....well....its more than half on the ground...
    all loaded up on the trailor
    took her out to the country to get wired up
  2. foto_choppa
    foto_choppa Member
    so ive done some more time filler-in work on this boat. mostly playing with carbon fibre some more. i shaved my centre console of pointless things like volume and temp control dealies, also the little cubby hole.
    painted it with some black epoxy sealant, mostly because the carbon fibre is actually transparent in 1 layer.
    laid down a layer of resin, let it tack off then laid over my carbon fibre cloth
    then wetted that down with resin, after this dried i gave it a good scotchbrite and laid over annother coat of resin to build it up
    this is after the 2 coats of resin
    you can see the texture the resin gets. its like super bad orange peel. its the imprint of the cloth under the resin
    it has removed all the orange peel and left a flat surface. i am going to go over this again tomorrow with 320 and then it will get cleared with 2k clear.
    this it it after i sprayed it with degreaser to put a shine on it to see how it will look.
    i like it. i know its just an overlay, but **** it. looks cool.
    - - - Updated - - -
    ive also made this aswell. bit of a process but here goes
    i got this display link. its going to tell me everything that i need to know about the car.
    it starts with some custom wood. all glued together with bog (bondo) -i am a panel beater afterall haha
    http://i27.photobucket.com/albums/c159/foto_choppa/20130110_124917_zpsd7c15da9.jpg
    plus one gutted out speedo screen
    shaped up the customwood wedge
    scuffed up the lens
    stuck the wood on and smoothed out the edges
    gave it a quick prime up
    got it properly 2k primed, rubbed it back and got one of the boys to hit it white while painting a van at work one day. just to get a gloss on it all
    laid down some gelcoat over it, followed by some layers of fibreglass
  3. foto_choppa
    foto_choppa Member
    and then i forgot to get images of it in the mould, but ta-da, one carbon fibre custom dash. its legit carbon fibre.
    dosent weigh much
    with the display attached
    it was my very first actual carbon scratch made peice, theres some flaws on it like theres too much resin at the top of the dash where it pooled in the mould. lesson learnt. also some air bubbles that could have easily been avoided too. i think what i'll do is paint the border bit thats embossed around the edges black. should look fine then.
    and i've also started to de-loom alot. theres about 1/5th the wiring in the car at the moment and i still have some more to strip out
    the harness up the back is the engine harness. that will not be getting used again. just some plugs off it. whole new engine harness will be made. the wires on the carpet are the entire car body, front to back and doors. haha.
  4. Jites
    Jites Active Member
    loving this build
    Your carbon fiber work is impressive, looks very neat
  5. Bjj Jacob
    Bjj Jacob New Member
    nice build dude, the front tub's look the biz
  6. haza88
    haza88 Active Member
    damn nice work man
  7. Swejky FC
    Swejky FC Member
    nice progress 8-)
  8. counteract
    counteract -o=me
    That cluster bit is smart as hell! Given me an idea haha!
    Car looks great!
  9. Tom_R33
    Tom_R33 Member
    looking good mate, mega fitment on the rear ;)
  10. Ricky Emery
    Ricky Emery Active Member
    Looks good. One thing why have you cut the arches?
  11. V-con Pro
    V-con Pro Active Member
    Impresive build dude,just how a soarer should be done.
    Im curious as to why you went for a 1.5jz? Was it just because you scored that long block? Im sure the 2jz heads are actualy better with larger ports, but still obviously better for making power/torque than a normal 2.5 1jz.
  12. foto_choppa
    foto_choppa Member
    Cheers for the comments.
    I cut and tubbed the front for 2 reasons. Firstly, i am running it quite low and i already had some rubbing problems when it was higher than it is now on full lock. Secondly....i think it looks cool.
    And the reason i went 1.5jz is because i bought the engine complete from japan for cheap. Rebuilt it fully, bearings, gaskets, all arp bolts and studs. All for alot less than a 2jz. Also 1jz parts are easier amd cheaper to come by. And also because the car is legal for a 1jz. This still looks like a 1jz haha
  13. Ricky Emery
    Hmm strange what wheels/offset you running up front? I've got 9.5j et12 GTRDs with a 25mm spacer and have loads of arch clearence.
  14. foto_choppa
    foto_choppa Member
    youre obviously not low enough then.
  15. mestew87
    mestew87 Member
    Is that the factory standard garnet red
  16. vdublou94
    vdublou94 Member
    Was massively impressed with your S13 bud, looking forward to seeing this!
  17. foto_choppa
    foto_choppa Member
    Yea, factory colour but resprayed obviously
  18. Ricky Emery
    No, i'm obviously not completely fucking my decent alignment and geo setup and adversely affecting the handling of the car by making it so low......lol ;)
  19. danielb
    danielb Member
    looking good man cant wait to see more!
  20. foto_choppa
    foto_choppa Member
    oh dont be like that with your 'practical tyre sizes' and 'text book grip'
