I have been looking for 2-way l.s.d. for my open diff s13 for a while. I emailed kaaz usa if they have a 2-way unit for me. they said that they propably have an unit for me and wanted to know if my diff is r180 or r200. it´s an r200 right? and how many bolts do the diff outputs have. I said I have 6 per side... Three ears sticking out with two bolts each. They say that they have an 2-way diff for me part number san2655 and that my diff is identical to the ones they have on the us spec cars without factory viscous. It should fit with the stock open diff outputs... Could this actually be true? It sounds too good to be true! So if I buy this it atleast fits in the casing? (like I have read that r200 units fit but outputs are different) and IF the outputs doesn´t match up I can just buy the non viscous outputs from us spec an us spec car?
It should fit into the casing, but the tricky part is getting the right output shafts, as I found. Best bet is get a nismo with the correct shafts, save any pissing about, like cutting open diff shafts down to fit as I did
It's a Fuktifino wassat 2 way Not sure what make, mate, as I took some pics and even Super JDM Tyte Yo Matt couldn't ID it They're on here or SXOC if you have a search for threads started by me..... Doesn't really matter as it does the job very well
